Originally Posted by
Snail Style
You can't hone bores on late model VW's as they have a silicon compound coating the sleeve. Honing the bore ruins the coating and kills the engine.
This is why I reckon a re-ring is pretty ineffectual. Not enough bore roughness to force the rings to bed in. Used to have the same issue on BMW motorbikes with Nickasil bores. The fix was to relign them with ci/steel inserts. There was a bit of meat to play with though and I doubt modern engines allow that luxury.
