How does the car drive? Low on power or noticeable change in power delivery to normal?
The clutch fault is more than likely to do with the Supercharger/water pump assembly, nothing to do with the transmission as some people may think after seeing the word "clutch".
See here as this is basically the same issue: Fault code P10A9
and here: 2012 Polo GTI - water pump fault
Roof lining is common of VW's (my Mk6 GTI started to do it). Around $200-300 should have a new roof lining installed by an auto trimmer. They can fix your door cards at the same time.
Part: VAICO Water Pump V10-50065 for Audi, Seat & VW
Good info: https://www.vacc.com.au/TechOnlineV2...0-10d8a4b1e0f1
