Results 1 to 4 of 4
Thread: GTi Magnetic Clutch Stuck Closed
    Jun 2013
    Brisbane, Queensland
    Unhappy GTi Magnetic Clutch Stuck Closed
    The car has got to a point it has had enough..... P10A9 00 [237] Magnetic Clutch Stuck Closed, and seems to have a small oil leak..... And the hood lining is dropping along with the front door material inserts.... Yay....
    Anyone had a similar issue with the magnetic clutch, what do I have to look forward to with the repair?
    Cheers, Matt.
    MY 13.5 Candy White Polo GTi, with Xenons....
    - Gloss Black roof, Weitec, Whiteline, APR and Harding Performance bits
    - Sound, Mosconi D2 100.4DSP, Mosconi D2 150.2, HAT L6SE Carbon
    List of things to add, custom built subwoofer enclosure by Drivesound
    How does the car drive? Low on power or noticeable change in power delivery to normal?
    The clutch fault is more than likely to do with the Supercharger/water pump assembly, nothing to do with the transmission as some people may think after seeing the word "clutch".
    See here as this is basically the same issue: Fault code P10A9
    and here: 2012 Polo GTI - water pump fault
    Roof lining is common of VW's (my Mk6 GTI started to do it). Around $200-300 should have a new roof lining installed by an auto trimmer. They can fix your door cards at the same time.
    Part: VAICO Water Pump V10-50065 for Audi, Seat & VW
    Good info: https://www.vacc.com.au/TechOnlineV2...0-10d8a4b1e0f1
    Jun 2013
    Thanks for the suggestion! Huge help.
    100% agree on the lack of power. It was almost like the throttle wasn't working. But did eventually build revs, and hesitate on auto shifting. So I was thinking the worst... Motor fix-up first (might take the opportunity to replace/upgrade other parts while its in pieces) then to sort the hood lining and door trims.
    MR
    Quote Originally Posted by RUFNIT View Post
    MR
    Ok so it seems the supercharger is disengaged therefore the low down power (so below 3,000rpm) you are used to isn't there anymore.
    I guess you can fix two birds with the 1x stone in this situation, as the supercharger clutch and water pump (both common issues on this engine) are both one and the same part.
