Results 1 to 10 of 18
Thread: Grinding manual ?
    Jan 2011
    Melbourne Australia
    Grinding manual ?
    car: 2012 vw polo 77 tsi 6 speed manual, 1600km's
    problem: every now and then, when i go to engage either first gear or reverse, it grinds the gear in, basically sounding like im not pushing the clutch in all the way. but every single time, the clutch has been all the way in
    someone said it might be the synchro's working harder to engage the gear, but this doesnt sound or feel right
    should i book it in with vw ?
    its embarrising going to put the car into reverse, and looking like a n00b, having it grind in
    Grinding manual ?
    Hey kam,
    Last time you brought this up I assumed it was just the clutch and gearbox continuing to spin and so the syncro's had to work harder and reverse would grind. But seeming it must happen often enough for a new thread, maybe taking it to VW wouldn't be a bad idea.
    As I said before, my sister's Polo grinds into reverse if you don't hold the clutch in for long enough, so I'd say that VW would just pass it off as 'a characteristic of the car' and tell you to leave.
    Anyway, if you're worried just take it to VW and see what they say.
    Alex Aescht
    MY13 Dark Silver VW up! 5-door 55MPI manual — Comfort Style Pack, Comfort Drive Pack, Maps + More, Panoramic Sunroof
    MY11 Pepper Grey VW Polo Comfortline 66TDI manual ― Comfort Pack, Audio Pack.
    Jan 2011
    Melbourne Australia
    Quote Originally Posted by alexaescht View Post
    Hey kam,
    thanks mate, appreciate that
    sometimes you cant hold the clutch in for ages, eg: doing a 3 point turn, you want to go from 1st gear > reverse > 1st as quick as possible
    having said that, each time the car has done this, its been completely stationary
    I don't believe reverse is synchronised on these bad boys (Well, it doesn't feel like it anyway)... If you are throwing it into reverse in a hurry, just use a little extra pressure so it doesn't grind for too long
    Grinding manual ?
    Quote Originally Posted by kam View Post
    That's ok
    I know what you mean about holding the clutch for a while, it's not exactly practical.
    How quickly do you shove it into gears - Do you let it sit for half a sec where the syncro's engage, or do you forcefully push it straight in? If you just push it straight in it might skip the syncro's and grind. I don't know if I'm right but it's a thought.
    Alex Aescht
    Grinding manual ?
    Quote Originally Posted by ecks View Post
    Yeah it's definitely not.
    Alex Aescht
    Jan 2011
    Melbourne Australia
    a bit of both, depends on how awake/how much of a rush im in.
    been in quite a few manuals and i dont recall them doing this ?
    ill try 'easing' it into reverse, and letting the shifter get 'sucked' into gear, see if that makes a difference
    Grinding manual ?
    Yeah I'm not sure if that will work with reverse but you can try. I meant to do that with 1st-6th as they're synchronised and reverse isn't.
    Sorry for not being clear
    Alex Aescht
    Aug 2011
    Melbourne, Victoria
    MY11 polo tsi manual owner here.
    If you are moving at all and engage reverse as they are straight cut gears for reverse it makes a charming crunch noise.
    First gear engagement is always smooth as butter. That said I always come to a stop before engaging it or reverse.
    As is said, if you're in a hurry to get it into reverse, just bang it in - minimize the time spent grinding the gears...
