I agree, it doesn't seem instantly useable, especially at home, but it really helps in busy fast food/shopping centre car parks where people frequently drive by even when you're initiating a reverse.
A little update after using this camera for a bit. Bottom line is that I really like it. The Polo is not a hard car to reverse, but the letterbox rear window can be hassle for some and for those coming from larger cars its amusing to note how far you can park a polo from the kerb and other cars without some practice LOL
Anyway, your own reversing skillz aside, the camera does help, not just in placing the car which most of us have no problem with, but also with what is behind of course. Its great to have an extra view and a simple check now and then is very useful when reversing and stops you running over things, or hitting low poles etc. If you can save having a bumper repainted then youve saved the cost of this mod already, save the need a tailgate or a light and youre in credit, etc etc.
So, would I do it again. yes I would. This mod was not something I expected to as good as it is, and... I use it more than I thought I would, even the Mrs said it was good, high praise indeed LOL!
So huge props to lunchy for the bracket and Staz and others for the help with the install and VCDS.
Bury S9 XL cradle for Touch Adaptor for sale: http://tinyurl.com/hgmjc4j
Sold my Shadow Blue MY12.5 3 door Polo GTI for a WRX Hyperblue...
SPOC - 1st Four.... www.DeskDivers.com & www.PloProf.com & www.2smoked.com & www.JonWallis.com
So exactly how do you do this in VCDS?
56-Radio, then long coding.
Mine doesn't have a RVC option it says four things in the long coding bit, only Bit 0 is ticked.
Bit O AUX-IN Access restricted (TICKED)
Bit 1 CD-Changer/iPod/UsB Connection Monitor (UNTICKED)
Bit 2 AUX-IN Connection Monitoring activc (UNTICKED)
Bit 3 Parking Aid Installed (UNTICKED)
Do i turn bit 0 off then put bit 3 on?
1976 Toyota Celica RA23 - 2L 6 Cyl S/C
1996 Mitsubishi Legnum VR4 EC5W - V6TT, AWD, AYC, Manual
2012 VW Polo GTi, MY13 - Xenons, Sunroof
Control Module 56-Radio
Goto long code helper
Click on Byte 3 (it's the fourth byte from the left)
Tick Bit 6 - Back-Up camera low
Thanks for that!
Alrighty - all done. Definitely a full on install. Works well though - very happy with it.
For GTI's pull apart the supplied cable so you have the coax separate to the 3 wires (red/yellow/black). The three wires only need to run into the boot, not the whole car.
Lift the purple clip on the coax cables blue connector - you will be able to slip it off and be left with a small metal square which is super easy to feed through the car/hatch/rubber thingy.
For the run up the hatch i ran a flexible bamboo skewer thingy, then used the excess in the coax to pull the three wires back down the hatch.
I attached the yellow cable to the bottom cable on the passenger taillight. To do this i opened the connector and soldered the cable to the metal connecting pin. Reclosed the connector and its very neat.
The black wire i put a loop on and attached to the ground point just next to the passenger taillight.
For the red wire i ran it down to the battery and put a loop on and connected it to the 30a point (non-GTI's will need to source constant 12v somewhere else sorry).
I got no power to the camera when i first did it (cables around the wrong way as spelled out by staz in post 20) - this is something of a gotcha if you install the badge unit first.
Thanks for everyone's awesome help with this guide, the bracket & the vcds help!
Good stuff mchieff. Glad you got it all installed and working.
Hey guys, any good place suggestion for install? not confident to do it by myself..thanks.q
I know that JKU ordered a bunch of them, they have installers in Sydney.
http://www.vwwatercooled.org.au/foru...tml#post862438
