You should have spec'd some Xenons.![]()
Bury S9 XL cradle for Touch Adaptor for sale: http://tinyurl.com/hgmjc4j
Sold my Shadow Blue MY12.5 3 door Polo GTI for a WRX Hyperblue...
SPOC - 1st Four.... www.DeskDivers.com & www.PloProf.com & www.2smoked.com & www.JonWallis.com
You managed to set off Nordic mode, here's some info on it.
http://www.vwwatercooled.org.au/foru...tml#post845764
It best to take things slow with VCDS, its easy to go wild and end up in a mess. I find having a break helps![]()
A few notes on the RVC.... most annoying install ever, more annoying than the Auto lights but here's a few tips.
There's a factory ground point in the hatch lid, just use that instead of having to run the ground through the to side.
There's no constant +12v in the hatch which is lame. I went direct from the battery (which is in the wheel well in the GTI). There's a line with a 30 Amp fuse on it, just use a loop crimp under the screw.
The sheath on the 24 pin connector is super easy to take off, just lift the two tabs up and pull the inner plug out. It's easier to run through holes and whatnot now.
Guys, can ew keep the chat in here limited to the install of the RVC? this is a DIY thread after all. I will look at cleaning this thread up too if need be for clarity.
Gavs, if youre game you could clean it up and at the same time put the pics&text in order for anyone doing this job, right now we have 3 peoples pics and its a bit jumbled. big job tho :/
Yeah, might be a couple of lunchtimes worth of work but that's a good idea.
