A big thanks to lunchbox and this thread.
I bought the RVC from the link lunchbox supplied in the first post of this thread. Took only a week to be delivered.
Also bought one of lunchbox's brackets.. which works perfectly.
All installed as per the instructions here.
The worse part is removing all the trim pieces.. arrgggh!!! The RVC loom gets run down the passenger side of the car.
Running the loom up the hatch cavity was also fiddly.
Everything is pretty much plug and play. There are only 3 wires that need connecting.
* +12V (red)
* neg (black)
* reverse activator (yellow)
I tapped my +12 (red wire) and neg (black wire) from the back of the RNS510 rather than fiddle with the fuse box.
The reverse activating power (yellow wire) I ran straight to the reversing light. The wire to tap off is Pin 2 on the passenger tail light plug. It's the wire at the bottom of the plug. See below for pics.
All working great.![]()
