Re: Golf pop out badge RVC into Polo 6R
Quote:
Originally Posted by
steveyoshi
Hey Jon, great article, well done and thanks... may look at doing this.
Did you happen to price genuine parts from the Stealership?
Are the Brackets (made) an extra cost or job to do?
What do you mean the size of the square on the screen, was it not full frame?
Stephen
No idea on genuine cost here, wouldn't bother myself as VW {factory} source these from a similar place themselves.
The brackets are definitely an extra cost, they were custom made by a member on here - nothing to do with VW.
The square size is when the video feed comes through there are "guide" lines IN the image {every rvc i've seen has these lines}. These lines are based on the golf as its a golf camera, so the "width" lines are a touch too wide. Almost guarantees we don't kerb the rims!
I've had the rvc in the car since almost new and the mrs and i still love it.
Sent from my Nexus 7 using Tapatalk 2
About a billion times better than rear sensors. The wide angle lens lets you see everything, very useful in carparks as you can see people walking in from the sides (and vehicles). It works with the std headunit. Best to pop it out and check if yours has the rear connector needed though, my my13 didn't, so I bought one that did (+300 or so) and swapped it at the same time.
Sent from my HTC One X using Tapatalk 2
The cameras will connect to an RCD510 as long as it has the extra camera connector - it varies between models.
The resolution is lower than the nav ver (RNS510), but it'll work - just wont look as good.
