Results 1 to 10 of 13
Thread: gap between front bumper and headlights
    Apr 2011
    Hey guys just asking polo owners in general (or more specifically those with a GTI that has the xenons).
    Do you find you've got quite a bit of a gap between the headlight and the front bumper? Quite visible in the dark if you use a torch to shine at it, you can pretty much shine straight through into the engine bay.
    Regards,
    Mar 2011
    Netherlands
    just went outside to check, no GTI but got xenon.. and no gap here
    Quote Originally Posted by PoloDave View Post
    Less than 3mm on mine...TSi
    MY18 GOLF 110TSI I HIGHLINE I Indium I Panoramic Sunroof I DAP I IP
    MY18 TIGUAN 162TSI I R-LINE I Ruby I DAP I IP
    Apr 2011
    Bringing it in to the service department tomorrow. Probably the clips came lose during transport or one of my spirited drives.
    yes it's spose to be like that, before i took out my headlight housing, it had that gap, put it back in it had that gap. and my car is only < 3 months old. checked with other polos as well, seems to have the same gap, my guess is that the clip under the housing actually nudges it up against the cross plate that bolts onto the chassis
    Dec 2009
    Adelaide,SA
    Quote Originally Posted by mr_bzr View Post
    Regards,
    HI guys, On my polo, i found a gap on oneside of front bumper ailment is wider than the otherside.Other issues to follow...
    Rattle Noise from rear left door.
    rattle noise from Driver top side window.
    Signal Indicator to the left blink extreme fast when it was raining.
    The right front light gets water into the edge of housing.
    rattling noise from engine under initial acceleration.
    Other than that on my experience,i wonder why other different type of cars like to accelerate off real fast against me at lights.
    cheers tay.
    Dec 2009
    Adelaide,SA
    [QUOTE=tay113;770682]
    (bumper taken out and readjusted /fix)
    (Put new added soft seals to stop rattles)
    (Change new weather strips)
    (updated software)
    (light was taken out and reseal)
    (found it was a electro magnetic actuator vibrating and waiting for parts coming tues)
    Latest issue i have found little black blemish like freckles on the rear bumper and next to the rear gti emblem.Seems like paint is too lite quoted.
    Have any of you guys with same issues.Thanks Tay
    May 2011
    [QUOTE=tay113;772841]
    Quote Originally Posted by tay113 View Post
    That's not exhaust soot is it?
    Polo GTI - 5 door - Candy White, Xenons, Comfort Package, Audio Upgrade, Bluetooth, Parking Sensors and Tint
    Dec 2009
    Adelaide,SA
    [QUOTE=prcurrie;772847]
    no .Its like someone at the factory doing a quick job and not enough layer of paint .Its so dejavu .On my ex golf gti and i had the bonnet sprayed as one spot became to change colour.Weird?
    smile.
    Jun 2008
    Ringwood, Victoria
    Could be industrial fall-out contimination. I have found it on my car too at some stages, I work in a faily industrial area, we have a paintshop and powdercoat line so fall-out is inevitable.
    Have a look at a product called "Wolfs Decon Gel", carcareproducts sells it. It's amazing stuff and it removed 100% of the contamination that was left in the paint AFTER a 1 hour claybar session!
    If it's still not coming off after a claybar and the decon gel, not sure what you could jo short of a machine polish, if indeed it is overspay as you say. Problem is, its VERY unlikely that its overspray. Those booths have very little wastage and can shoot multiple colours without cross contaminations quite easily. They don't have painters either, they're robots.
