Results 1 to 10 of 72
Thread: Fuel
Mikefc Fuel 24-03-2013, 03:01 PM
wai There can be differences,... 24-03-2013, 03:20 PM
gavs Fuel 24-03-2013, 08:55 PM
MrDeathLad Where would one procure such... 24-03-2013, 09:05 PM
Lemonskin I always use BP. tried Caltex... 24-03-2013, 09:13 PM
Polo_GTI BP ultimate FTW 26-03-2013, 01:56 PM
ill0gitech I only use Shell Vpower, and... 26-03-2013, 02:29 PM
ATYPIC May as well just say Caltex... 26-03-2013, 02:29 PM
nomadx38 Any more than 0% ethanol is... 26-03-2013, 06:22 PM
gavs Fuel 26-03-2013, 10:27 PM
Diesel_vert Depends who you ask. ... 27-03-2013, 12:35 AM
ill0gitech Is the United 100RON more... 27-03-2013, 07:29 AM
Martin A few people on this forum... 27-03-2013, 08:09 AM
Martin It's often quoted in motoring... 27-03-2013, 10:43 AM
Diesel_vert Okay, I wouldn't exactly call... 27-03-2013, 10:52 AM
nomadx38 Actually they had this exact... 27-03-2013, 08:37 AM
ill0gitech Agreed, except that the... 27-03-2013, 09:07 AM
Martin Yes - I remember that test -... 27-03-2013, 09:20 AM
gavs Fuel 27-03-2013, 08:58 AM
nomadx38 The price is sort of... 27-03-2013, 09:48 AM
Diesel_vert Source? As will... 27-03-2013, 10:30 AM
Martin The price spread between E10... 27-03-2013, 10:28 AM
nomadx38 Main reasons I don't use it:... 27-03-2013, 11:09 AM
Diesel_vert The manufacturer, VAG... 27-03-2013, 11:24 AM
pologti18t I have used Liberty 100 in my... 27-03-2013, 03:14 PM
alexaescht Fuel 27-03-2013, 03:27 PM
Diesel_vert 'No biodiesel' actually... 27-03-2013, 04:04 PM
alexaescht Fuel 27-03-2013, 05:07 PM
PoloDave Not entirely true, there is... 27-03-2013, 08:07 PM
nomadx38 You don't happen to live/work... 27-03-2013, 09:01 PM
PoloDave you are correct sir :) And... 27-03-2013, 09:50 PM
Drooberius Have a question... I want to... 04-04-2013, 07:14 PM
Diesel_vert In most cases, the fuels will... 04-04-2013, 08:01 PM
nomadx38 That can be worse for your... 05-04-2013, 01:50 PM
Drooberius Just on a slightly side... 16-04-2013, 12:06 PM
Diesel_vert It's generally advisable to... 16-04-2013, 07:16 PM
PoloDave Saw 5th gear yesterday with... 16-04-2013, 08:52 PM
wai It's not the crap you can see... 17-04-2013, 07:20 AM
amazeer I have been told that the... 17-04-2013, 06:12 PM
wai In all the underground bulk... 17-04-2013, 10:36 PM
nomadx38 The light comes on when the... 16-04-2013, 12:27 PM
gavs Fuel 16-04-2013, 01:10 PM
ATYPIC Geez...and I thought driving... 16-04-2013, 01:37 PM
Hail22 http://www.vwwatercooled.com.a... 16-04-2013, 01:57 PM
alexaescht Fuel 16-04-2013, 03:16 PM
nomadx38 Yeah definitely not right! I... 26-04-2013, 09:16 AM
alexz my GTI gets MINIMUM 500km to... 26-04-2013, 11:02 AM
Yaks1974 Agree with the others you... 26-04-2013, 03:00 PM
nomadx38 Just wondering but are you... 26-04-2013, 03:14 PM
Mikefc mmmm, okay - will look into... 26-04-2013, 08:51 PM
MJKooLio Silly question... or maybe... 29-04-2013, 05:14 PM
nomadx38 I'm pretty sure you can but... 29-04-2013, 05:19 PM
amazeer Definitely not. Shell E10 is... 29-04-2013, 08:58 PM
alexaescht Fuel 29-04-2013, 10:53 PM
Hail22 ATF is quite cheap at the... 29-04-2013, 11:04 PM
MJKooLio Fuel 30-04-2013, 06:27 PM
amazeer new cars that can run on... 30-04-2013, 09:34 PM
wai The RON is not the only thing... 30-04-2013, 09:56 PM
    Jul 2012
    Is the United 100RON more expensive than 98RON at other stations?
    If so has anyone tested 100RON with 10% Ethanol for fuel efficiency?
    The previous Fuel Efficiency tests I've seen with same model cars, and cruise control showed that E10 95RON and 98RON in that order were the best value for money
    Dec 2012
    Sutherland Shire, Sydney
    A few people on this forum have used United petrol & desiel only to have a fault light come on - fuel filter had to be cleaned
    At the MRT Track day they recommended Caltex 98 followed by Shell 98
    Ethanol emissions can damage the core of catalytic converters
    Quote Originally Posted by ill0gitech View Post
    Ethanol has less energy than petrol, you have to burn more of it to achieve the same outcome, this needs to be factored into the price/economy equation - if the price differential is wide enough E10 can be the cheapest to run, but not by much
    (If you have a turbo VAG car then 95 and 98 fuels would be the go)
    Dec 2012
    Quote Originally Posted by Martin View Post
    Quote Originally Posted by Diesel_vert View Post
    Source?
    It's often quoted in motoring articles, e.g:
    E10 fuel a false economy
    Jan 2009
    Okay, I wouldn't exactly call that an authoritative source.
    Lol, it looks as if he just put in that last line for fun.
