Don't expect much difference acko, aside from the badge your going to be hard pressed to tell the difference. Take a look at carsguide.com.au and see if you can tell the difference...
I am keen to see what the subaru looks like. I hope the interior is better.
Check out topgear Australia's 14 things about the 86.
http://www.topgear.com/au/photos/14-little-86-things
It may not be as upmarket as a GTI but I find the plastics usually last longer than rubberized parts. Plus I love the center aligned tachometer. It's like a prerequisite to be considered a true drivers/sports orientated car
The Subaru BRZ 86 has a different suspension set up to Toyotas 86 and i feel will be the better built unit and hold its resale value slightly better than Toyotas ....... however its still not a True sports car IMHO
I just don't wanna open a car door and get in it.....Then realise....Oh NO!....I am in a toyota haha....I must sound like a bit of a snob but they are so boring.
I don't see the difference....Audi's are a waste of money. unless u get quattro.
Resident grumpy old fart
