Results 1 to 10 of 18
Thread: Front rotor replacement issues. 8/2010 77TSI
    Apr 2015
    Labrador, Qld
    Hi All.
    Just wondering if anyone else has experienced the same or has any advice. As we live on Tamborine Mountain, we get a fair bit of brake temp driving to and from work etc... i.e up and down. Ive ended with the usual warped brake rotors on the front and have started looking for replacements. As a trade qual mech myself it isnt an issue but I found the following.
    All brake catalogues show either 256mm or 288mm rotors. Whats actually fitted is 239mm rotors. I've looked towards europe for replacements and it seems 239mm rotors on my 6R were actually fitted on the 6N-1.
    Im not going to fit OEM or cheap after-market. I'll bring in or buy locally if possible Brembo Max or sport replacement rotors and either Brembo or EBC pads.
    Has anyone found the same or done a rotor replacement with a decent quality brand?
    Cheers Dan
    Dec 2008
    Sydney/Canberra
    I'd recommend brands like ATE, or Textar, for both pads and rotors.
    You can source them through HSY and Imparts locally.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Apr 2015
    Labrador, Qld
    Quote Originally Posted by Umai Naa!! View Post
    Thanks for the information, greatly appreciated.
    Brakes Direct up in QLD have a great range and well priced too. Send them your VIN and they will tell you what choices you have.
    Mar 2012
    Brisbane, Australia
    Interesting because my front rotors are warped as well- I've been happy to put up with it until they need replacing *shrugs*. Is this a common problem on these cars?
    Dec 2008
    Sydney/Canberra
    Yeah, for some reason warping on the base model brake package is quite common.
    '01 Beetle 2.0
    Oct 2010
    Melbourne, VIC
    Quote Originally Posted by OUR6R View Post
    This astounds me given that they uprated the brakes on the TDi from 256mm to 288mm, even though the 6R TDi was a lot less powerful and probably lighter than the 9N3 version.
    No wonder warping is an issue with such small rotors on the 77 TSi but then it all helps with fuel economy and acceleration.
    I would also recommend contacting Brakes Direct/GSL RallySport - I have found them to be extremely helpful and knowledgable. I have bought DBA rotors and QFM and Remsa pads from them and they have been better than the OEM parts IMO (longer lasting, better performance on track days but maybe a bit less initial bite).
    Resident grumpy old fart
    Quote Originally Posted by kaanage View Post
    We've got a TDI and its on its second pair of front rotors after the originals warped. The new ones have only been on for about 30,000km and are already starting to shudder.
    Alex Aescht
    MY13 Dark Silver VW up! 5-door 55MPI manual — Comfort Style Pack, Comfort Drive Pack, Maps + More, Panoramic Sunroof
    MY11 Pepper Grey VW Polo Comfortline 66TDI manual ― Comfort Pack, Audio Pack.
    Oct 2010
    Melbourne, VIC
    I've never had the 256mm DBA rotors warp, either, despite getting them red hot on several track days
    See here and also here
    The stock 288mm rotors I've fitted as an upgrade seem to be warping though (and no track work on these so far). They'll be replace with DBA's if they get worse
    Apr 2015
    Labrador, Qld
    Quote Originally Posted by trive2 View Post
    Ive read quite a few posts on this happening on Polo's so maybe its an issue with heat dissipation and dis size?
