Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Front rotor replacement issues. 8/2010 77TSI
    Apr 2015
    Labrador, Qld
    Thanks all for the responses...
    Aug 2013
    Quote Originally Posted by Umai Naa!! View Post
    I'd recommend brands like ATE, or Textar, for both pads and rotors.
    You can source them through HSY and Imparts locally.
    I have actually followed Umai Naa's advice and bought ATE rotors and ceramic pads for my CC... They have been great performance wise, low noise and dust... If you buy them together you will get 3 year/50000 KM warranty...
    I bought them directly from HSY Artarmon.
    Good luck
    Jan 2009
    Just so I'm not preaching the "disc don't warp" message:
    -Warped- Brake Disc and Other Myths
    Doesn't mean this standard discs aren't crap, though I'd be leaning towards pads being equally crap causing your grief.
    Daily: 2010 VW Jetta Highline
    Jul 2007
    Brissy
    I am a believer that warped rotors is not very common at all, and usually something else is at play.
    I had ECB pads which deposited material on the rotors and made it shudder. I had to remove and lightly sand the rotors to clean it up and they were fine a gain for 20,000km or so. Also found a rotor was not seated very well after a tyre rotation, the little screw had broken off. The back of the rotor had a bit of rust too, so a clean out and some light grease fixed that for many km too.
    The bmc pads eventually failed, came off the backing plate and had to be replaced, under warranty too after 6 years.
    If your brakes are fading then maybe some slotted or cross drilled rotors would help, also change the brake fluid more often as once the fluid heats up it looses it efficiency.
    I too would recommend GSL Rallysport/Brakes Direct, tell them your issues and I'm sure they will have a recommended pad and rotor combo suited to the hills.
    MK4 GTI - Sold
    MK5 Jetta Turbo - Sold
    Aug 2013
    I thought my car was abnormal warping at 60,000km.. Or I was braking too hard.
    Sort of good to see other people have this issue.
    Sort of a bummer though cause I still have 75% of my pads left on the front, and if i get the rotors machined I'll have to do the pads too
    I Sell Nissans Skodas.
    IT'S HEREEEEE 18' Skoda Octavia 110tsi Manual Hatch | Race Blue | Tech Pack | Luxury Pack | Panoramic Roof | Turini Alloys | Various VCDS Tweaks | RS Spoiler | Mars Bar Holder
    R.I.P; 13' VW Polo 77tsi Comfortline Manual | Candy White | Sport Pack | Pioneer AVH X3800DAB + Clarion Bass Pack
    Apr 2010
    Rowville,Vic
    I read somewhere that you should not use the hand brake when parking the car after a hard brake use as it could cause the rotors to warp
    MY19 Polo GTi 2.0 DSG
    Previous VW cars:MY16 Polo GTI manual, 2007 Jetta 2.0 TDi manual, 2001 VW Bora V6 4-Motion - flooded away
    Adelaide hills, SA
    Quote Originally Posted by maxrob200 View Post
    It's usually the front ones that warp, not many manufacturers have parking brake acting on the front wheels.
    Jan 2009
    You are correct, though the chances of getting them hot enough on the street then stopping immediately is unlikely. The issue is pad compound transfer to rotors. I've had that issue after track sessions resulting in a clear pad imprint to the rear rotor. For street driving, it's much less unlikely unless it's a mountain run or something.
