Results 1 to 10 of 13
Thread: front grill/ headlight removal
    Aug 2012
    Albury, NSW, Australia
    would anyone one here be able to post up how to remove the front grill and headlight unit for the 77tsi?
    any help is appreciated.
    cheers, Ben
    @mrdeathlad
    #rollinonskittles
    Shorty exhaust, black tails, Kw V1
    Ronal, Oz, Hoshino Racing
    Melbourne, Victoria
    For the headlight look in your manual.
    2011 Polo GTi
    Jun 2008
    Ringwood, Victoria
    Don't think it's in the manual but to get the headlights out, undo the wiring plug, undo the 2 top bolts and then push forwards. For the grill, I'll need to check the manuals.
    Oct 2012
    Sorry to hi-jack the thread but can anyone help me with removing the front VW badge?
    The Matt black one I ordered just arrived and it seems to have three clips on the back which should just clip in. But how do I go about removing the stock chrome one? Anyone done it before?
    Thanks
    Melbourne, Victoria
    Quote Originally Posted by gavs View Post
    Gavs it is in the manual because I used it when I changed my headlight bulbs.
    2011 Polo GTi
    Oct 2012
    [IMG][/IMG]
    [IMG][/IMG]
    here's the pics of the badge showing the clips... anyone?
    Jul 2012
    Quote Originally Posted by cstb_87 View Post
    100% in the GTi manual. would hope the same goes for the 77TSi regarding changing bulbs.
    Mk8 Golf GTI
    Jul 2012
    I've done both. Headlight = 3 bolts (or 2, all on op visible), grille = 4 torx screws on top, clips along top and bottom but be firm when pulling it towards you (standing from front)
    Also for badge, take off mesh backing, then turn VW badge (cannot remember if anti clockwise or clockwise) and it should pull out. Hard to explain but it'll make more sense when you're doing it! Good luck!
    Aug 2012
    So on the tsi, there is two torx screws to undo on the grill. Then four clips that hold it on at the top. I can get this far then the bottom resists quite a lot. Feels like something on the bottom is going to break, are there there more clips? Is there a trick to it?
    Jul 2012
    Quote Originally Posted by MrDeathLad View Post
    Once all the top screws are removed, on the GTI that's it. You need to give it a good pull, or if you can get your hand behind, a good push. There's clips underneath which put up a fight. Whatver you do, don't try to swing it side-to-side to get it to budge, as there's a metal triangle as part of the corner section of the body that's sharp and can scratch/crack the glass. Straight out.
    But that's the GTI
    . I can't speak for the TSI, though would assume it's the same set-up.
    Mk8 Golf GTI
