Results 1 to 10 of 14
Thread: Polo GTI 6R stock ride height?
    Mar 2013
    Sydney, New South Wales
    Hey guys,
    Wondering what the stock ride height of the front and back of the GTI? I've been googling and can't seem to find anything.
    The Weitecs are scrubbing slightly at high speed when turning or during some bad roads at speed.
    Trying to figure out how much I should raise the car.
    I'll measure it tomorrow and see what it is now but I'm not sure how it's measured!
    Any help is much appreciated! Thanks guys!
    For reference:
    Mods: 18x7.5 Tenzo Tracer, EZ Lip, Piano black front/rear emblems, Metallic foot rest, Gloss black vinyl wrapped roof, Weitec Hicon GT coilovers, HP CAI
    Apr 2013
    Quote Originally Posted by llai8501 View Post
    Hey guys,
    I measured mine last week before I fitted 18" wheels -
    Stock ride height 2013 Polo
    Arch height to ground Front: 635mm
    Arch height to ground Rear: 668mm
    I measured vertically from the ground up through the centreline of the wheel to the lip of the guard.
    I find the thread -
    http://www.vwwatercooled.com.au/foru...ght-85362.html
    very helpful
    'bigfoot' please measure and update your ride heights when you get a chance
    2015 Polo GTI with DA pack : Milltek Turbo back exhaust | DD spacer | JB1 | VWR Turbo Intake elbow and intake hose | BMC panel filter | KW Street Comfort coilovers | Whiteline adjust. endlinks | Harding DSG Perf. tune | Wagner Intercooler| Dotz Mugello 17 x 8 32ET
    Mar 2013
    Quote Originally Posted by car_nut View Post
    I find the thread -
    very helpful
    Thanks I'll try!
    Jun 2008
    Ringwood, Victoria
    Ride height according to the technical specs is 351mm+/-10mm for the front and 367mm+/-10mm for the rear.
    Mar 2013
    Quote Originally Posted by gavs View Post
    Is that measuring from the arch to the top of the tyre?
    Looking online people seem to measure from the ground to the arch in line with the wheel cap.
    Thoughts?
    Apr 2013
    That would be from wheel arch to centre of wheel.
    My corresponding standard wheel/tyre/suspension measurements were front 343mm (just inside spec) and back 370mm. I expect every std. Polo GTI is different.
    Thanks Gavs.
    Your car doesn't even look very low - its probably just the offset of your wheels that's scrubbing when you hit a bump or go through a corner fast.
    Mar 2013
    Can you explain what this means? And as the scrubbing is light and occasional when driving hard or bumpy am I at risk of much damage?
    My friend suggested raising it 5mm and seeing it it helps.
    Thoughts?
    Thoughts?
    Sorry - mabye i should have explained more clearly. What i meant was that its not like your car is super low/slammed or anything. So wondering why its scrubbing? Your aftermarket rims might not be the optimum offset (offset meaning how far they stick out from the hub) and this (combined possibly) with the width of tyre you are running might be your problem.
    Do you know what offset your rims are? And what width tyre are you running?
    Mar 2013
    Thanks for the clarification!
    I am on this I believe:
    Tracer V1 18x7.5 5x100/114.3 42 73.1
    From here:
    http://streetandcircuit.biz/tenzor/c...es-tracer.html
