Those are ugly fog lights, I found these and would not mind getting them. The only thing I will do is to wire them so that they come on when switching on the head lights and not use them as fog lights
Polo_6R_10_Front_Fog_Light_Kit_Polo_6R
FOG LIGHTS LAMP GRILLE SET FOR VW POLO MK5 6R 2010- | eBay
$100 AU - seems good value - but wiring them would need to be done outwith the stock light switch me thinks....
MY18 GOLF 110TSI I HIGHLINE I Indium I Panoramic Sunroof I DAP I IP
MY18 TIGUAN 162TSI I R-LINE I Ruby I DAP I IP
POLO 77TSI DSG 5D - MY11 - REFLEX SILVER - COMFORT PACK
Engine - K&N Air Filter (e-2997)
AV - Rockford Fosgate T1652-S , T1652 and P3L-S12 Sub. Alpine MRP-F600 and Alpine MRP-M500, Dynamat
Planned - lots, but the "financial manager" says NO
Yep, friend got a $100 fine.
Hence why here in Australia, the DRL function is programmed into the dipped beam headlight, not the front fogs like overseas.
Yep, because it is illegal accross the whole country to run fog lights when it is deemed by the officer involved the conditions do not require the use of fog lights. If the programming has been set for the fog lights to be used as the DRLs then the dealership the car was bought from needs to re configure the settings.
All australian specced cars should use the dipped beam / parker globe mounted in teh dipped beam.
I suppose you could replace the reflector & bulb with some sort of LED DRL set-up. But if you're thinking of something similar looking to a fog light without the glare, you'll have trouble convincing a police officer that it's not a fog light. No issue with an engineering certificate of cause -but the dollars involved in getting one of those...
MkV GTI Pirelli | APR tune
