Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Failed actuator
    Jul 2012
    Sinagra, Western Australia
    Quote Originally Posted by Snail Style View Post
    Just make sure the campaign for the wastegate shims was done correctly.
    I win!
    Mar 2011
    Melbourne, Victoria
    I win!
    I bow down to you
    2011 Polo 77TSI Manual Comfortline | Flash Red | Sportspack | Panoramic Sunroof | Front Tints | Euro plates
    Nov 2012
    Sutherland Shire, NSW
    From what I understand the 24v9 campaign applies to only a certain batch of VINs, which seems to be prior to 2012ish. Last service I had no luck convincing the dealer staff that I wanted this carried out, because my VIN supposedly does not match the affected batch. Certainly seems it should be carried out given this thread. Has anyone else managed to convince their dealer to have this done on their car, or am I worrying over nothing?
    Current: 2018 Golf GTI Original | Manual | Tornado Red
    Previous: 2012 Polo TSI | Manual | Reflex Silver | Comfort and Sports Packs
    Jul 2011
    Worrying over nothing mate. There was a re-casting of the turbo+manifold which from what I can see was 2012 onwards. With this update the turbo actuator moved from a 45deg angle to a almost horizontal position. I would assume when they moved the position they would have added 2mm to the cast to put more tension on the actuator rod which is all the shim does in the 29v4 update.
