View Poll Results: Material vs Cost
Voters
13. You may not vote on this poll
  • Aluminised Steel
    10 76.92%
  • Stainless Steel
    3 23.08%
Results 1 to 10 of 20
Thread: Exhaust material, GTI owners, your opinions?
    Ladies & Gent's,
    Need your assistance on the final steps for our Polo 6R exhaust - materials & cost.
    We have traditionally only offered hand finished stainless steel, we are working with a new manufacturer who can offer awesome quality with a choice of materials.
    Who would like to see an aluminised steel version available & save $400 - $500 over a traditional Stainless steel version?
    Aluminised steel lasts a long time, probably in street use, longer than the vehicle itself - the system will still have full stainless mufflers & tailpipes.
    It is possible that we can offer both materials, but initially in batch quantities, we will only offer one material.
    Expected pricing:
    Aluminised full turbo back system, 200 cell metal cat, stainless mufflers & twin walled 75mm tailpipe tips. $1995 incl GST
    Stainless full turbo back system, 200 cell metal cat, stainless mufflers & twin walled 75mm tailpipe tips. $2450 incl GST
    Jun 2008
    Ringwood, Victoria
    ALuminised steel all the way. We build (through a separate company arm) aluminsied steel fuel tanks and for the cost saving over stainless, it makes you wonder why people still insist on stainless. The other benefits include:
    Less suceceptable to stress cracks
    Easier to weld (for those not good with a tig)
    Better heat disipation (less heavy metal in the alloying)
    Less brittle when hot
    On a side note, what is (other than strength) the benefit of going to twin-walled?
    Quote Originally Posted by gavs View Post
    Thanks Gav's - awesome feedback!
    the twin wall is the exhaust tips - they look nicer & you can clean the inner lip as well. I'll try to post a couple of pics of the tips. We are very happy to get it out at this price considering the complexity of the heat shields. I have already seen the results of no heat shields & its not pretty.
    Apr 2011
    Sunshine Coast, QLD
    Would there be a difference in weight?
    If the aluminised stuff is cheaper AND lighter, and will likely last as long... it seems it would be a no-brainer...
    2011 Polo GTI | Black | 5 doors | Comfort pack | Audio pack | 9w7 Bluetooth | Xenons - a Return to VW!
    Previous ride: 2008 Mazda2 - ZOOM-ZOOM indeed!
    1st Ride: 1988 Red VW Fox Sedan!
    Good question Rob, I don't think there would be much in it weight wise, I'll try to find out.
    The market I understand has been driven to stainless steel over the past couple of decades due to the early 80's (and earlier) use of mild steel & harsh winter salt.
    You standard Polo uses aluminised steel pipes & stainless mufflers anyway!
    Jun 2008
    Ringwood, Victoria
    Yeah, exactly. While stainless is stronger than regular mild steel, it's also less forgiving and has a much closer yeild:failure ratio. When stainless yeilds, it will generally fail pretty closely, especially with un-intentional heat treatment, such as in an exhaust.
    Apr 2011
    Sunshine Coast, QLD
    I'm surprised you don't think it would be much lighter. Obviously, I know very little on the topic...
    Is it because the parts ate small and light to begin with? Or is it because of the process? What is meant by aluminized steel anyway?
    On another note, while winter salt may not be a consideration here, what about the salt from our coastal habitat?
    Jun 2008
    Ringwood, Victoria
    Coastal Salt isn't an issue, while the air is more laden with salt it is not to the same extent as the european roads in Winter. I have been over there when they are salting the roads and it is litterally like an old, wheely bin garbage truck laying down a mix of rock salt and fine gravel. Imagine constantly driving though beach water and sand for 3 months and that's what it's like. We just don't get those conditions here.
    Aluminised steel is a somewhat "New" alloy in that the constituants aren't alloyed together but the aluminium (not Aluminum, stupid americans, can't even correctly spell an element!) is fused, similar to a plating to the outside of the steel. It's a better, more stable and more environmentally friendly to zinc plating or galvanising. You would be more likely to see a weight saving advantage toward the alunminised steel but it wouldn't be really worth considering....
    Will try to weigh an OE system vs ours when we next do an install.
    Apr 2006
    VW Race HQ - Sydney
    no option for titanium ?
    Bug_racer supports the rebellion of the euro revolution
