Results 1 to 7 of 7
Thread: ESP Error HELP!
    Jan 2014
    Queensland
    ESP Error HELP!
    Hello guys, I wanted to start the car today and the MFD showed ESP Error and the P light on the DSG is flashing and I can't move it.
    I can't start the car either.
    (Will try to tow it to the nearest VW dealer tomorrow and get the diagnostics done)
    Any advice would be much appreciated
    Thanks
    Jan 2013
    Brisbane, QLD.
    7Speed DSG? Sounds like Mechatronics.
    Check your SC6 fuse, it will probably be blown. Get the car towed as it will need the campaign done.
    Mar 2013
    Brisbane QLD
    No signal from mechatronics....tow job mate.....VDUB
    VOLKSWAGEN TECHNICIAN - 16 YEARS OF PAIN..
    VCDS CODING- FAULT DIAGNOSIS - PRE PURCHASE INSPECTIONS- REPAIRS
    9W2 BT KITS -$300 - 9W7 BT KITS - $450 - CANBUS UPGRADE $150
    BRISBANE / GOLD COAST
    Jul 2011
    VCDS would be a great help, but there are many things that could cause this fault. It could be as simple as the brake switch not working which will show the same symptoms.
    If you have a multimeter check all the fuses, the ones under the steering wheel, fuses on the battery and the little plate in the engine bay where the battery would normally go.
    Jan 2014
    Queensland
    Thanks for all the replies, I will probably get it towed to the nearest VW dealer since it's still under dealers used car warranty, from the place that it was bought from, and they can check everything. But at least I know now what it could be.
    Thanks again
    Jan 2014
    Queensland
    Got it towed today, will see how it goes after the diagnostics and all the check ups
    (Updates coming soon )
    Jan 2014
    Queensland
    Got my car back today from Cricks Auto Group - Home it was the DSG recall (mechatronics) which hasn't been done from the dealer (this place http://www.irelands.com.au/ ) that the car was bought from, they said it was (liars) actually the sales person checked everything before the car was bought and said that everything has been done
    So they have to pay for the towing + some compensation because I was without a car for 5 days
    All good now
    (thanks for all the replies again)
