If I am parked with motor running and Clutch depressed
Select 1st Gear - Engine idles at 650rpm
Select 2nd Gear - Engine idles at 650rpm
Select 3rd Gear - Engine idles at 650rpm
Select 4th Gear - EPC light comes on, engine runs roughly as fuel (or sparks or both) turns ON and OFF*
Stop/Start system will be in Engine Not Running error. This typically doesn't go away for ten minutes
You really don't want to have low throttle in 4th gear whilst driving because this gets really ugly
So I generally just use First, Second, Third and Fifth Gears
I am guessing it may only be OFF for say 100 ms
It could also be noted that I often get the Stop/Start error "Engine not running" in normal driving even if I don't select 4th gear
