Originally Posted by
nomadx38
Hey alexaescht,
First off I don't own a diesel car, I love my pet-trol-lol! But thinking about your problem I would say it could have somthing to do with a pressure sensor in the DPF. Just doing some brief research on the DPF apparently it burns off the soot by either injecting fuel directly into the DPF or by increasing exhaust temperature by means of late ignition or controled misfiring. The reason I say it could be a sensor is because the sensors monitor the back pressure on the exhaust and DPF to prevent damage to the DPF, engine and exhaust from the hot explosive pressure. Also the pressure can prevent combustion exahust from exiting the cilinder which can result in poor fuel economy, staling and lack of throttle response.
Why didn't the sensor throw up a check if its damaged? I would assume its the same problem I have with my DSG (cultch solienoid sensor doent work accurately so it drops the clutch every gear). The problem is that the electronic part hasn't failed compleatly so is still making a circuit and thus not throwing up an error. This is what I have and diagnostics show nothing wrong with the garbox. I went with the vw tech for a drive and within 5mins he said that's not right and I am now due in for a mechatronics unit and new clutches because of the damage that could have been caused to them as a result.
What would I suggest? Well before my test drive I went around the area a few times and noted when it would play up at certain speeds, braking, stop start on hills etc, and during the test told him to do it that way and that's how I showed him. You may have to do a similar thing if diagnostics show nothing wrong.
Also could try going through the mountains with high revs (you know a real spirited drive) to manually clear out the DPF and see how it goes.
