Results 1 to 10 of 10
Thread: Eibach Pro Kit Polo 6R
    Jul 2012
    Endeavour Hills, Victoria
    Has anyone Installed an Eibach Pro Kit ona polo 6r? What are the little metal rings for?
    May 2012
    What's the link?
    MY16 Candy white Octavia VRS Wagon, sunroof, 19" black pack, tech pack, comfort pack, auto tail gate
    MY12.5 Polo 6R GTI
    Feb 2013
    Sydney NSW
    Just installed on mine.
    metal ring is to stop a full turn lock so 18inch plus wheels dont rub.
    So if normal wheels, dont use them.
    Jul 2012
    I run 17x7 inch wheels. they still fit within the manufacture specifications. So they should be alright then?
    Feb 2013
    Sydney NSW
    Quote Originally Posted by 6rtrendline View Post
    No problems with 17" . not even close to rubbing.
    check photo of mine on pic thred.
    1st photo stock 2nd photo eibach.
    Jan 2009
    blankedy
    I don't understand how the rim size would affect the tyres rubbing...
    when you put bigger rims on, you reduce the tyre size to compensate. Maybe more relevant for wider tyre spec's
    Nov 2012
    Johannesburg, South Africa
    here by us, the H&R kit is preferred.
    Reason being, the Eibach drops the front and back by the same amount, so the car ends up with the rear higher than the front.
    With the H&R drop, its staggered, so it brings the front and rear to the same height, which looks better.
    Jul 2012
    Difference be tween the 2 kits is 10mm in the back.
    I chose the pro kit because its not uncommon for my car to have 4 people in it or be completely filled with camping gear.
    Jun 2008
    Ringwood, Victoria
    10mm isn't even an accurate tolerance to hold on spring manufacture. VAG have a tolerance on most models of +/-30mm. 10mm could be compensated for by carrying 100kgs in the boot for the first week after installation
    Hey did you ever install this kit? I'm getting the VW Lowering kit (30mm front and back like you) and I also have new 17inch alloys with 215/40 tyres. Could you possibly post a picture when you get your wheels and springs on as I'm getting that exact kit (well it's the same as the VW supplied one)!!!
