Absolutely normal. It's interpreting that you want to maintain your speed so it shifts down to help. It gets it right a surprising amount of the time
Wondering if this is normal: when I drive the new Polo and I come to a steep hill, when using the break to keep the (60km/h) speed limit, the gearbox kicks down to 3rd gear and revs over 3000rpm. Before I put my foot in the break to keep speed it's in gear 6 or 7 and then kicks down to 3.
Normal?
VW Tiguan 2018 162TSI Highline
VW Polo 2015 81TSI Comfortline
Resident grumpy old fart
Engine braking.
'07 Transporter 1.9 TDI
'01 Beetle 2.0
I don't notice this on my s-tronic Audi A4, but maybe it's more subtitle given its a higher end car?
The programming will be completely different for the larger engine which will provide more engine braking as well as "normal" power and torque
Try not releasing the brake pedal completely while going downhill, just gently modulate. Certainly it downshifts the second time I touch the pedal without using the gas pedal in between. Our 2004 BMW does the same thing and it can be annoying when you want to coast a bit. I have to briefly tap the gas to get it to upshift.
Maybe rather than use the brake, anticipate that you are going down hill & back off a fraction earlier & use the gearbox rather than brake?
Or use tiptronic to select the hear you want. The manual recommends 3rd gear for steep declines and general advice is not to ride brakes for an extended period of time (ie down a mountain).
I really don't think the OP is complaining about the car slowing down too much but is just querying the gearbox behaviour.
