Page 5 of 10 FirstFirst ... 34567 ... LastLast
Results 41 to 50 of 94
Thread: DSG "False Neutral" Yesterday...
  1. #41
    Aug 2006
    Far North Qld
    Quote Originally Posted by gavs View Post
    To answer questions regarding the "shuddering" For anyone who has had a manual that has a slipping clutch or a clutch on it’s way out, you will know this feeling. Generally, it will happen when you load up the torque through the gearbox, like in a low speed acceleration out of a corner. This causes the clutch to slip against the flywheel.
    Yes, it is a known issue, especially in the GTI polos. Yes, there is a fix as I have already had this fix applied to my car, it’s about a days’ worth of work. Yes, it is covered under warranty.
    gavs, is there a code / reference we can quote to avoid unnecessary delays in dealership accepting claim?
    White 3-dr Polo GTI
    Tiguan 189TSI
  2. #42
    AutoBahn
    What is the "fix" you had done Gavs? also as the above member asked, is there a code/reference number for this to be carried out? I've noticed my car is slipping between 2nd down to first once leaving my driveway going up quite a steep hill...its as if the car wants to cave in and die in the bum.
  3. #43
    Jun 2008
    Ringwood, Victoria
    There isn't a specific service campaign but if you go into the dealership and go for a drive with the tech and you can prove the clutches are slipping then they will replace them under warranty. There has been revisions to the friction materials used in the 7spd dsg clutches to hopefully fix this issue.
  4. #44
    Aug 2006
    Far North Qld
    Quote Originally Posted by Hail22 View Post
    Gavs, are you happy with the fix and do you consider it a permanent one...?
    White 3-dr Polo GTI
    Tiguan 189TSI
  5. #45
    Jun 2008
    Ringwood, Victoria
    Well the clutch slipping is no longer occurring so yes, is it permanent? Well I sure hope these clutches last longer than 20,000kms but realistically clutches should last in a road car to at least 150,000-200,000kms depending on use and type of compounds.
  6. #46
    Apr 2012
    I'm going to have to get this checked as well. I'm not sure if VW are going to be very helpful in getting it resolved but again I heard it today on my way to lunch so the problem is still there.
    How do you know these things gavs... do you work for VW at all or something?
    GOLF GTI MY11 ADIDAS Candy White, Sunroof
    GOLF GTI 40th ED, White with Sunroof
  7. #47
    AutoBahn
    Car is booked for the 27th of July (to get a loan car) They believe it will take them 1-2 days to complete as they would prefer to pull the front a part to get a better idea of what is going on.
    Do you have any further information about the "updated" friction materials used in the new clutch gavs?
  8. #48
    Apr 2012
    What did ou tell them hail?
  9. #49
    AutoBahn
    Quote Originally Posted by Bassik View Post
    I told them that during low speed cornering, exiting my driveway which leads to a very steep hill. The car stutters as well as hearing the gears grinding against the flywheel. Notified them that I once had an issue on a very steep hill that the gearbox engaged 3rd gear which led to the car to roll back...very dangerous.
    Test drive not needed as they're pretty much aware its a clutch problem.
  10. #50
    Jun 2008
    Ringwood, Victoria
    Bassik, no, I don't
    Hail, aside from the fact it's the second revision of the clutch material which happened 02/12 that's all I know. Makes me wonder about aftermarket clutches...
