Page 4 of 10 FirstFirst ... 23456 ... LastLast
Results 31 to 40 of 94
Thread: DSG "False Neutral" Yesterday...
  1. #31
    Quote Originally Posted by Bassik View Post
    This is all well and true but why wasn this happening previously and now I have just noticed it? I'll be honest it hasn't really caused any driving hick ups other then the false starts on take off. The noise was never there before, it may very well be the DSG just doing its thing but the noise it makes doesn't sound health IMO.
    As gavs suggested, you might want to get VW to look into the noises you are hearing. The only info i can offer on this is that the brand new (had 90km on it) Skoda Fabia vRS i drove last week also had audible metallic clicking noises coming from the gearbox during gear changes. It has the same 7 speed DSG as the Polo GTI.
  2. #32
    Apr 2012
    Yeah could be right, I'll drive it as per usual and get VW to have a look at it. I'll also get one of those other guys to do a service and cancel the VW service. Might do a little tuning.
    GOLF GTI MY11 ADIDAS Candy White, Sunroof
    GOLF GTI 40th ED, White with Sunroof
  3. #33
    Aug 2006
    Far North Qld
    this may slightly OT, but I notice my DSG (at low speeds just after take off) feels like it running on corrugated road, so a slight vibration. Been doing it for a little while, and is still doing it after recent DSG update (recall 37G7)
    any thoughts?
    White 3-dr Polo GTI
    Tiguan 189TSI
  4. #34
    Jun 2008
    Ringwood, Victoria
    Normally in 2nd gear take offs with a decent amount of throttle input, but not enough to kick down a gear? If so, new clutches.
    Regarding the 37G7 campaign, all of the talk about improved gear changes, better kick down etc will be gone within 2 weeks of the update because what the campaign does is it tells the computer to fully seat the shift actuation solenoids when the car is stopped instead of sitting at a "ready to engage" position. This prolongs the life of the solenoids, that is all. The reason people get the different feeling straight after the update is because the software in the gearbox is reset. Disconnect your battery overnight and reconnect it and it does the same thing. 37G7 does not in any way influence the way the car drives unless of course you had a solenoid on its way out already.
  5. #35
    Aug 2006
    Far North Qld
    Quote Originally Posted by gavs View Post
    thanks Gavs, is getting new clutches normal...I mean easy to get service to accept a wty claim?
    secondly, Yes, I did notice the "improved" stuff and yes, it has already worn off...
    White 3-dr Polo GTI
    Tiguan 189TSI
  6. #36
    Apr 2012
    I have been getting this recently as well. Would this have any relation to my so called gearbox issue? Something tells me that all the issues I'm having are related but really I can't need a new gearbox and clutch already... it's not even a year old?
  7. #37
    Apr 2012
    I am getting the exact things you are referring to and am on my second gearbox. Gavs if you wanted to take my car for a spin to see the difference between yours and mine it might be of assistance putting people minds at ease...
  8. #38
    Apr 2011
    Sunshine Coast, QLD
    I've been getting this "shudder", for lack of a better term, too. For about a month, now.In 1st and 2nd, at low revs and especially when the car is cold. I've taken to using manual mode to keep the revs a bit higher until warm.
    I haven't been advised to get the DSG update, and couldn't find the info on erWin. I thought after reading other posts that the update would resolve this. Thanks for the info on what the update actually does, gavs.
    Incidentally, how DO you get this technical info that even the service guys can't seem to get their hands on? You must have some freaky connections!
  9. #39
    Apr 2012
    Quote Originally Posted by RoknRob View Post
    True that....
    ... and yes comparing the 2 cars would be putting peoples minds at ease because I have noticed the shudder as well and it's be more noticeable after software update.
  10. #40
    Jun 2008
    Ringwood, Victoria
    Honestly, you don't want to know and I'm ashamed to admit to doing it.... .
    To answer questions regarding the "shuddering" For anyone who has had a manual that has a slipping clutch or a clutch on it’s way out, you will know this feeling. Generally, it will happen when you load up the torque through the gearbox, like in a low speed acceleration out of a corner. This causes the clutch to slip against the flywheel.
    Yes, it is a known issue, especially in the GTI polos. Yes, there is a fix as I have already had this fix applied to my car, it’s about a days’ worth of work. Yes, it is covered under warranty.
