Try and disconnect the other side and see if it brings up the error.
Hi,
So my driver side Fog Lamp isn't working, shouldn't I be getting a warning light?
Or does that show that it isn't a bulb and I should give the dealer a buzz?
It may not be set correctly in the cecm module to detect it. If you don't have a cable, try to get someone to check. Mine was happy without any fogs it wasn't set. When I set monitoring, it detected when the lights were unplugged
Sent from my RM-821_apac_australia_new_zealand_304 using Board Express
08 MY09 R32, DBP, DSG, GIAC, R8V10 reps, KW V3, RNS510/VIM/BT/MDI, region free DVD, switched Haldex, s2t paddles,HPA dogbone rubber,Mk7 climatronics, FIS+, Adams/RDA discs & Hawk pads, Garage button, GruppeM. Front fogs, Milltek. CF Chin spoiler.Strut support. LEDs Alloy front suspension bits.....
http://photobucket.com/gregsr32
Thanks, I might have to disconnect the passenger one tomorrow. No access to a VAG-COM unfortunately.
The car is only a few months old and I've only used the fogs a few times so I'm surprised one has gone. But you do get bad globes sometimes I guess.
no warranty on globes/bulbs.....cold bulb monitor doesnt always work for all lamps... depends on year..model..and set up... my jetta blows one No plate light bulb and no warning.. when the other goes it put the dash warning on. .. swop over the bulbs just to check but sure it will be a blow bulb only....VDUB...
VOLKSWAGEN TECHNICIAN - 16 YEARS OF PAIN..VCDS CODING- FAULT DIAGNOSIS - PRE PURCHASE INSPECTIONS- REPAIRS9W2 BT KITS -$300 - 9W7 BT KITS - $450 - CANBUS UPGRADE $150BRISBANE / GOLD COAST
just make sure first you dont have turning lights! put light on driving beam then turn wheel in left lock to see if left lights up then right lock to see if right lights up.... ive seen so many people not know this and leave there steering on a slight angle and think one side is inop!! VDUB....
I initially thought it might be something little like that when stationary, but it clearly isn't working when I turn them on while driving.
It's going in to the dealer next week when my new wheels arrive so they said they'll look at it then.
