Results 11 to 20 of 23
Thread: DNA Stage 1 tune 77tsi.........time to upgrade.......what your thoughts?????
    Jun 2009
    Ohh it will be a damn tight fit - if its fits. Do you think you'll be able to shoehorn a R32 engine and gearbox into a much smaller Polo engine bay?
    Someone overseas has done an R36 engine + drivetrain swap in a 9n3 polo so it is doable.
    AutoBahn
    Like i said before, I will make it happen as i will be requesting a TUV approved company to build me rear and front fendors like the Polo R rally in case the wheel base is wider which most likely will be.
    And as Team_v said its doable but i want to complete it to perform/look like a factory built car.
    Nov 2010
    Quote Originally Posted by Hail22 View Post
    I'm actualy saving now to do an "R" project by getting a Mk 5 R32 motor and box, strip the car and rebuild it to be a pocket racer.
    sick
    Similar to the Moffat Rx7 I co-own with the bro we pulled out the original port 13B rotor engine and replaced it with a 26B rotary engine exactly the same one used in the Mazda 787B Le Mans car.
    SICKEST!
    MY18 Golf 7.5R - Ecotune Stage 1
    Mazda RX2 - 13B Bridgeport GTX4202R
    Jan 2008
    Sunshine Coast
    Hats off to DNA then, I am awaiting a response from Viezu, as I have one local guy keen as mustard, and I'm sure his patience will run out!
    Jun 2008
    Ringwood, Victoria
    Yes DNA has a tune available for the 77tsi motor, look at a power increase to 100kw.
    Quote Originally Posted by gavs View Post
    Which ECU though?
    May 2011
    Mickleham, VIC
    Mmmmmm thinks i want this tune for sure now, i want more midrange.........the stock midrange is still impressive, if a little soft........
    hopefully with a bit more boost (psi) from the tune the dsg fart will be more pronounced
    Next: Mk 5 Golf R32 (in blue please)
    Now: 2014 Skoda Yeti 90tsi Ambition TECH PACK
    Had: 2012 ABARTH 500 esseesse
    Had:2010 77tsi DSG7, Comfort Pack, Reflex silver
    Oct 2010
    Melbourne, VIC
    Which ECU though?
    I thought they all run the Simos 10.2
    If they do, then DNA Tuning can remap them via PC software + cable
    Resident grumpy old fart
    Jun 2008
    Ringwood, Victoria
    Dan, yours is an early build polo yeah? In which case, John should be able to tune it no probs. Speak directly to John to confirm though. So long as the ecu isn't a MED17.5.5, will be pretty straightforward. There is always viezu too as an option.
    Jan 2008
    Sunshine Coast
    Nope, Viezu can't do the later ECU yet either, I am on their case about it for a guy up here. For Viezu queries in Vic, have a chat to John at Tigersoft, he's been a BMW specialist, but is doing a ton of VW's lately!
