I get confused .. discover pro, discover media? Same as MIB1? Or MIB2? Or neither lol. I know I have MIB1
MY15 Polo GTI - Red - DA Pack
If you use an independent to service your car and are therefore likely missing out on the free map update with dealer service then this may be of use to you.
DiscoverCare < Innovation & Technology < Volkswagen International
Select download for Windows or Mac. It will install software on your PC that automates the update process. At some stage you will need to insert your original VW card into the SD slot on your PC etc. A backup of existing sat. nav. data will be done to PC before the card is updated. Make sure you select Multi Region Map 2 when given the options.
Worked like a charm for me, now have 2017/18 maps.
2015 Polo GTI with DA pack : Milltek Turbo back exhaust | DD spacer | JB1 | VWR Turbo Intake elbow and intake hose | BMC panel filter | KW Street Comfort coilovers | Whiteline adjust. endlinks | Harding DSG Perf. tune | Wagner Intercooler| Dotz Mugello 17 x 8 32ET
Harry
MY15 RED Polo GTI 6C - with DA Pack
Yeap.. same as yoursmight give that a go... if this works I won't be going back to the dealer for my 30k service which I was thinking off for all the software updates. Thanks for the info mister! Much appreciated
Harry
Hi ya
Had issues with this. This was due to size issue and bare in mind I am a Mac user.
Here is my work around
1. Download software as above.
2. Let it go through as intended.
3. Mine was failing at 92% installations phase.
4. Navigate to DiscoverCare/Data
5. Unzip the large file that is in that folder
6. Navigate to SD card, go through the folders, you'll find folders called map blah blah and remove any file/folder that says Seat/Skoda
7. Navigate to folder in step 5 above.
8. You will need the last folder called EEC or something similar copy entire folder to SD card replacing existing.
And you are done.
It was failing as the last folder being copied across was to large for the SD card.
Hope this helps
Harry
awesome! thanks for the tip. fully updated my maps now. cheers
I got my car dealer serviced and they didnt do this for me! grrr so a massive thank you to car_nut for this, i have updated it now, took about 1hr 30 all up but just left it going on the laptop, nice and easy![]()
2016 MY17 Polo GTI with DA package. TMD fitted + Weather strip and Snow Screen removed otherwise dead standard.
lol sneaky! we'll allow it!![]()
