Results 1 to 10 of 16
Thread: Dimmed headlights?
    Mar 2011
    VIC
    Dimmed headlights?
    Hey guys,
    Not sure if this is an issue or not, but i noticed that my headlights seemed to have dimmed for a moment (happened a couple of times in a row) when I was parking my car. I noticed it whilst the lights were shining up on the brick wall in front of me.
    Is this an issue? or something else?
    Also, a second question, how do you turn you lower lights (fog lights?) on whilst your main headlights are on? I turn my dial to the right for the main headlights but not sure how to have them all running.
    Thanks for the help.
    Mar 2011
    Quote Originally Posted by PatoriaN View Post
    Just pull the dial towards you.
    Jul 2011
    when your headlight selector is in main headlights mode. then pull the selector out ONE click, towards you to turn your foggies on. pull it out further (a second click) and your tail foglights'll turn on
    Jan 2011
    i think your referring to the static cornering lights. when you turn left or right the corresponding fog light also turns on. so when your parking and turning into the spot an extra light will turn on and then when your straighten up it will turn off.
    Jun 2008
    Ringwood, Victoria
    Hey guys,
    Your owners manual funnily enough has a wealth of knowledge in it in regards to answering these type of questions. Does the dimming happen when you're turning your steering wheel? It's possibly your static cornering lights illuminating and then turning off.
    Jun 2011
    Sydney NSW
    As others have pointed out, there are ways to do this, only you also need to be aware that Australian road rules require the headlights to be off when the fog lights are on. This is mainly because there are no aiming/light pattern requirements for fog lights and if used in normal conditions can be blinding to oncoming drivers.
    You might even see warning notices on freeway/motorway signs reminding drivers that it is an offence to use fog lights other than when there is fog. You can be fined for using them at other times or in conjunction with dipped headlights.
    Essentially, fog lights are auxiliary headlights and so are used in place of headlights.
    Driving lights are additional headlights and can be used with headlights, however if used with dipped headlights, they must be aimed and meet the light patternrequirements for dipped headlights. If they can't be aimed or meet the light pattern requirements for dipped headlights, then they must be connected so that they can only be turned on when headlights are on high beam.
    Mar 2011
    VIC
    Thanks for the info guys, I appreciate the help.
    I am aware of the road rules for them, just wasnt sure how to activate them when required! You can tell that I have been driving a very old car
    Ill have to check the cornering and the lights, it was whilst I was parking so this is likely it. I havent seen it happpen whilst driving normally.
    PS - I did check the manual, which has been very helpful, obviously I missed this believe it or not, its actually embarrassing asking that question!
    Jan 2011
    on the topic of fog lights. what about the new passat they seem to have their yellowy fogs always on a DRLs. thats technically illegal ye?
    Jun 2011
    Sydney NSW
    Quote Originally Posted by JexL View Post
    I don't believe that DRL's are legally required as not all new cars have them, and so they can possibly get away with it as long as they go out (which they do) when the headlights come on. As fog lamps, yellow is perfectly OK, and actually preferred as it is the blue portion of white light that scatters and causes a lot of the back glare in fog. This is also why the French have their cars with yellow headlights.
    Aug 2011
    Melbourne, Victoria
    I think one point which has been overlooked is the fact the vehicle in question has electromechanical steering. When the car is at lower RPM levels, the steering mechanism will load the electrics causing the lights to dim slightly. This is normal.
