Originally Posted by
Giannislp
I also have the same question! I want to make a maintenance of the gearbox and thinking about also changing the hydraulic fluid of the mechatronics. It also has a drain port at the bottom and I was thinking to add 0.9l of fresh fluid from the breather cap. Will it be usefull this renewal or it is better not to try it at all?
Dont touch it ever as was enough trouble with incorrect oil from the factory causing corrosion and then needing replacement at about $4000 a pop.
