Page 1 of 5 123 ... LastLast
Results 1 to 10 of 41
Thread: Dead Throttle - extreme lag? ... dangerous!
    Hi,
    has anyone else had this intermittent problem since having both the DSG software and turbo shim/spacer upgrade;
    I thought it was my imagination until my wife borrowed the car and mentioned the same concern. Twice when taking off from the lights, ive had zero response from depressing the throttle. Pushing it much further down eventualy caused the car to move and then surge as the turbo spooled.
    I thought it was a one off until it happened to me a second time - in second gear, slowed at a give way, pressed peddle to merge with traffic and it felt like the engine had died - the car coasted out onto the main road. I pushed the throttle hard to the floor and it seemed like seconds past before power returned. The car behind clearly had to brake to accomodate me.
    Needless i am going to the dealer for a check, but want to know if anyone else has experienced this?
    MY18 GOLF 110TSI I HIGHLINE I Indium I Panoramic Sunroof I DAP I IP
    MY18 TIGUAN 162TSI I R-LINE I Ruby I DAP I IP
    DSG brain (mechatronics) sounds like its playing up.
    Jul 2012
    I've had this happen, and happen at the worst times - both when changing lanes and almost getting rear-ended.
    Don't think I've ever had it in S or M, only in D.
    Pressing harder gave me a kick, but it certainly wasn't turbo lag, it was dead-dead. Not even at more than a slow roll.
    Can't replicate it deliberately, which is a pain to get checked.
    Apr 2010
    Mine improved a lot after mechatonrics were replaced as well, prior to that I was using a SprintBooster to make the acceleration kick in earlier
    Aug 2012
    greensborough, victoria
    happens to me a couple of times a week i thought it was normal lol.
    what do they do to fix it?
    Quote Originally Posted by polojdp View Post
    Dont know (yet) - but will post any positive update after the dealer sees it next week.
    I also noticed the car seems to slam into first when taking off - there's no gentle progressive take up...again not all the time but 'bang' into first and off it goes.
    May 2011
    Melbourne, Vic
    I've also had this issue in my GTI. Had it happen to me about 6-8 times in 17 months, including twice while on the move. The DSG in my car just doesn't like coasting slowly as if to stop, then accelerating again. It's best if you're about to stop and the car in front moves, to just stop and then go again. Seems to eliminate the issue for me.
    That said, I've just had my DSG software updated at the 30k service and it seems to operate much better, even in stop-start traffic. Hopefully the issue won't surface again.
    2011 Polo GTI. 3dr, Flash Red, Audio, window tint.
    Jul 2012
    Not sure if this is the same issue, both myself and the OP both mention it's come from a stop to starting again. I can say in both situations for me, I've been stopped a while, and tried to change lanes - needing a squirt of power and not getting anything.
    In fact, my GTI loves coming from a slow down in second, to punching away when a light changes to green. I've never had a car where that didn't feel awesome
    Mk8 Golf GTI
    Apr 2010
    You're probably on the accelerator sooner (at higher rolling speed) than the other guys reporting the issue. Tends to be an issue just as the clutch is about to go in to prevent stalling. DSG tune fixes issue since it downshifts into 1st.
    Jul 2012
    I do love me a quick take off, so probably.
    These definitely sound like two different issues.
    Mk8 Golf GTI
