Page 14 of 15 FirstFirst ... 412131415 LastLast
Results 131 to 140 of 142
Thread: Daytime driving lights.
  1. #131
    Apr 2012
    I asked many people what I should put in my low beam and everyone said H7.
    to my knowledge there are two sets of head lamps. The Gti has the 2 separate ones. Which is 2 sets of H7's. Plus H4 connectors are different to my knowledge, so wont fit. The H7's went in fine.
    GOLF GTI MY11 ADIDAS Candy White, Sunroof
    GOLF GTI 40th ED, White with Sunroof
  2. #132
    AutoBahn
    Hey Bassik i remember you wanted interior lights correct?
    I deliver!
    10 pcs White led Interior lights kit for VW POLO 6 R Canbus No Error SMD set | eBay
  3. #133
    Apr 2012
    Quote Originally Posted by Hail22 View Post
    I deliver!
    10 pcs White led Interior lights kit for VW POLO*6 R Canbus No Error SMD set | eBay
    Nah I have interior LED's already (at the front) I need to know how to take the capping off from the back so I can replace them. Also notice that my main interior light is constantly on like even when the car is off. I'm assuming this is because they require such low voltage there is still a very low current going through them 24/7
  4. #134
    Aug 2012
    sydney, NSW
    So after 3 months. What was the end result for your lights Hail 22
  5. #135
    AutoBahn
    The rears and front LEDs?
    Worked like a charm,
    However i need to ask someone where i can find coding for the DRL/LED...I found a unit with HIDS/Halogen instead of Bi-Xenon (its the exact same as the Bi-Xenon unit minus the Xenon globes!).
    The biggest plus is it changes from LHD to RHD!
    I just need the coding...otherwise error central...
  6. #136
    Apr 2012
    May I ask where you found these? There not Dectanes Daylines are they?
  7. #137
    AutoBahn
    Just like when i first found the ABTs going to keep it hush hush until they arrive, unfortunately being the first customer of these lights i need the coding for the original DRL/Xenon to prevent fault/error codes popping up.
  8. #138
    Aug 2011
    The Xenons have their own CAN module/section in VCDS, not sure if you wanted that but here's the only coding for the Xenons in the BCM (which is itself different to your BCM)
    http://www.vwwatercooled.org.au/foru...tml#post808791
  9. #139
    AutoBahn
    Hmmmm should i purchase one of these to avoid error codes?
    Pair HID Xenon Warning Error Code Canceller Capacitor VW Jetta Golf Audi A4 A6 | eBay
    Because So far the guy building the unit is playing around a way to instal the Halogens or HIDs to sit behind the projection glass dome, but needs to test the focus to prevent light separation (basically light going everywhere hitting other road users in the face).
  10. #140
    Aug 2012
    sydney, NSW
    So after reading all your comments you ended up with
    Parker light: Volkswagen Polo 6R 2009+ Error Free Side Light Bulbs LED | eBay
    Then low beam lights you put on Phillips crystal vision: H7 bulbs
    High beam you put on osram H7 bulbs?
    Then LED for your number plate from eBay Australia: Buy new & used fashion, electronics & home d
    Question:
    Got any new pics with all your lights on?
    Did you end up with any error codes after putting those on ?
    And Im guessing you didnt end up doing the VCDS to have only your parker lights on whilst in day light mode the "o" position on the light dial?
