Page 7 of 15 FirstFirst ... 56789 ... LastLast
Results 61 to 70 of 142
Thread: Daytime driving lights.
  1. #61
    Mar 2011
    Netherlands
    I would go for the Osram Nightbreaker Plus, very polular over here for its white light
  2. #62
    Jun 2008
    Ringwood, Victoria
    I would go the Osrams or if you can find them, the IPF globes. Don't get anything higher than 4500K in colour because even at 4500K you have a severe drop off in penetration, the more yellow the light, the greater the penetration of light, hence why road markings above the snow line are yellow, the yellow penetrates through fog etc so you can see the lines.
  3. #63
    AutoBahn
    Would the nightbreaker plus compliment or go well with Volkswagen Polo 6R 2009+ Error Free Side Light Bulbs LED | eBay
    Thats my concern...
    Also the polo is H7?
    parkers are T10/W5W?
    What are the fog lights? bum bum ba! *stunned face*
  4. #64
    Mar 2011
    Netherlands
    fog lights are H8, let me check the forum over here for pics
  5. #65
    AutoBahn
    Looking forward to pics
    Wanting to do the following:
    -Low Beam (Osram Nightbreaker)
    -High Beam (Osram Nightbreaker)
    -parker/side globe http://www.ebay.com.au/itm/Volkswage...item19cefcb361 ?
    -Fog light change (Brand-Unkown)
    So all the help is welcomed!
    making sure that i'm aiming for a white/crystal white.
    Wondering if what I have lined up thus far will look OEM/Not over the top
  6. #66
    Mar 2011
    Netherlands
    Pics availably are all phone quality so not really usefull.. One of the members has the Phillips Diamond Vision and says they are even whiter than the Osrams and come pretty close to the LED's he has in his parking light
  7. #67
    Jan 2009
    So far, I've counted five different versions of daytime running lights for the 6R Polo.
    Daytime running lights in the fog lamp housing:
    1. Fog light + optional static cornering light (H8 35W bulb) and DRL (P21W bulb).
    1a. Fog light + optional static cornering light (H8 35W bulb) and no DRL.
    2. DRL (P21W bulb) with no fog light.
    Daytime running lights in the main headlamp housing:
    3. Dipped beam DRL (H7 55W bulb).
    4. Gas-discharge headlights with integrated DRL (LED modules).
    Daytime running lights above the fog lamp housing (VW genuine retrofit):
    5. LED-Tagfahrlicht fur den Polo. Part number is 6R0052190.
  8. #68
    Apr 2012
    Ohhhh... How do you get those last LEDs you mentioned?
    Doesn't the Polo have H4 globes as well think I read in manual somewhere?
  9. #69
    Jan 2009
    Quote Originally Posted by Bassik View Post
    (Shrugs shoulders...) contact the dealer? Google the part number?
    Ah yes, forgot about that.
    Polos with a single headlight use a twin filament H4 60/55W bulb, those with dual headlights use a pair of H7 55W bulbs.
  10. #70
    Mar 2011
    Netherlands
    Don't know if you have the 1.2 TDI over there, but many over here have found out that ECU versions 88A and 88B are extremely sensitive for canbus light errors. Still not a big deal, easy to disable with vcds.
    Don't know if VW has put these ECU's in more TDI's though
