If your lucky, you may be able to access that area of the dashboard from underneath the dash. All the a/c fans/motors etc are in there, but you may be able to see the permit if you dig around and use a bright torch. Another option would be to remove the glove box and see if that helps with locating it.
- Removal of dashboard will cost a fortune and no doubt you will end up with rattles/scratches etc
- Removal of windscreen will be cheaper, but still expensive - and you may not have enough access to get to the permit.
- Contact council to get renewal of permit would be my #1 option after checking yourself under the dash/glovebox first. Surely if you have been granted a permit previously, you should be able to get another one. Tell them your car was broken into an it was stolen?
