Drive it.
Big day. CV boot change, oil change, attempted new headlight.
Bought a new headlight because the low beam didn't work d/s.
New headlight low beam doesn't work. Checked and changed some fuses, found the pos battery terminal loose so fixed that and didn't that create havoc?
How do I reset all of these?
I have a cheap obd bluetooth that doesn't show any codes.
'11 Polo TDi auto, White, Sunroof
'91 Transporter syncro camper
Drive it.
'07 Transporter 1.9 TDI
'01 Beetle 2.0
Yeah tried that. No steering.
I'll go through the fuses again.
Need to get it over 20km/h.
Also check that you haven't damaged your wheel speed sensor.
'01 Beetle 2.0
Drives well. Nearly pulled my shoulder doing a u turn.
No chnage to alarms.
All fixed, bar the low beam on DS.
