Results 1 to 10 of 11
Thread: creaking spring dash noise
    Oct 2011
    South Australia
    Can anyone tell me what the creaking springy like sound that comes from the passenger side when you go on and off the throttle is?
    It's not a plastic thing I'm pretty sure, more like a creaky spring sound but not the suspension.
    Any info would be great. The car is going in next week to have a fog light fixed so it'd be handy to point them in the right direction beforehand.
    Thanks.
    Oct 2011
    South Australia
    Wow, am I the only one with this?
    Hopefully the dealer knows what it could be, I'll post next week just in case anyone else ever has anything similar.
    Pacific Paradise QLD
    Quote Originally Posted by dening View Post
    Might be the spare keys in the glovebox LOL
    Jun 2011
    Sydney NSW
    It could be a loose dashboard mounting with the body moving just a little as you go on and off the throttle.
    Now, no matter how "stiff" you might think the body is, Hooke's law can be written to read that something must deflect to resist. No movement, means no load. It does not take much. I have designed large (triple 400 kW conveyor drives) that had problems of alignment when someone would walk on an adjacent walkway. The movement was a fraction of a millimetre, but enough for a precision pin to not align with the holes.
    Jun 2012
    Ringwood, VIC
    I tended to hear something like that too. It was there only upon take off and rather quiet. Sounded like a creaky spring.
    Turned out some sort of rubber washer in the transmission had shifted and was causing the noise, but it seemed to be coming from the passenger dash area. My dealer found it and fixed it under warranty
    Oct 2011
    South Australia
    Quote Originally Posted by mathemagician View Post
    Cool to know that one.
    My dealer had tried to fix it according to a tpi for a squeaking front bush which had it lubed, but this hasn't worked. I'll mention the transmission thing next time I drop it in.
    Sent from my GT-I9100 using Tapatalk
    Jun 2008
    Emerald, Vic
    I get some noise when i engage the clutch, like slack in the gearbox being picked up, or a transmission mount knocking against something..
    My Car(s): 2011 6R TSI Comfortline (Pepper Silver),
    If you're in need of any 6n1 parts, odds are that I am going to have them (dismantling 2 at the moment)
    Oct 2011
    South Australia
    So after another trip to the dealership it has been diagnosed as the washer from the transmission. A part has been ordered.
    Sent from my GT-I9197 using Tapatalk
    Jun 2012
    Ringwood, VIC
    Seems to be a general Polo (GTI) thing then. Glad you can finally get it sorted.
    VW Polo GTI ~~ MY12.5 ~~ Flash Red ~~ Bi-Xenon ~~ Alcantara/Leatherette
    Jul 2012
    I have a spring sounding squeak from the passenger side as well but I've narrowed it down to the passenger side air vent. If i apply a little bit of pressure just to the right of the vent, it goes away...not sure if this is the washer for the transmission.
