Results 1 to 10 of 17
Thread: Coolant top up
    Apr 2011
    sydney
    Coolant top up
    Anyone topped up their coolant levels yet? Ive done about 7k on my polo tsi. Just checked the coolant level and found its a tad below the minimum level when cold. Manual states to add G12 Plus-Plus or G12 Plus. Should I head to my dealer for this? Or would somewhere like super cheap have it?
    Also engine has not chewed any oil so far.
    AutoBahn
    Got the same thing, no warnings yet and service is in a few weeks time so i gather its all good. Must be in all TSI's quite a thirsty bugger when it comes to heat reduction xD
    I have Nulon Red long life top-up Coolant, think its safe to use for the TSI? :/
    Jan 2009
    Quote Originally Posted by marcs View Post
    Dealer only. I doubt the retail shops would stock it.
    Must be one of the lucky ones!
    Quote Originally Posted by Hail22 View Post
    Nope.
    Refer to the owner's manual for further details.
    Jun 2008
    Ringwood, Victoria
    Your dealer might offer free top ups seeing as a) it's brand new and b)it's a sealed system so theoretically, it shouldn't have used any coolant because there isn't anywhere for it to go, which would mean it was over-looked in predelivery....
    Apr 2011
    sydney
    yeah ill just go to my dealer. No warning lights coming up either. But I definitely remember seeing it above minimum at least when i first got it thats for sure. I drive the thing like a baby.
    Apr 2011
    sydney
    guys i just rang the dealer. They told me its not necessary to top up until the warning light comes on. And in the case that it does they said its safe to top up with water. do I trust them? hmmm
    Jun 2008
    Ringwood, Victoria
    Hell no!!!!!! It says to NEVER top up with water in your owner's manual!!!!
    You introduce water, you dilute the glycol levels etc and can rust out your cooling system! I would leave it and monitor it over the next few months. If it keeps dropping, take it back under warranty.
    Mine dropped below the min once, and I topped it up with mineral aquifer water (not) and it's stayed put ever since. I recon its just on the initial run in. Checked it twice since, and it hast not moved.
    MY18 GOLF 110TSI I HIGHLINE I Indium I Panoramic Sunroof I DAP I IP
    MY18 TIGUAN 162TSI I R-LINE I Ruby I DAP I IP
    Adelaide hills, SA
    Quote Originally Posted by gavs View Post
    The small amount (less than 1/2L) can be topped up with demineralized/distilled water. The factory fill is strong enough to take it. Of course ideally you should use 50:50 mixture. Also remember never mix 2 different brands of coolant, use only G12+ or G12++ coolant as per your user manual. After you topped up with water, at your next service you need to tell your mechanic to measure the coolant concentration and adjust, if needed.
    Jun 2008
    Ringwood, Victoria
    Yeah, that makes sense Transporter I'm just going off what the owner's manual says and with having to fully strip out and clean the cooling system of a 4wd I owned due the flog before me topping up with water, I personally never endorse the use of water in any cooling system, but that's just me
