Use the recommended proper stuff or you will ruin your engine as different spec stuff is not a good mix
Hi
I need to top up my coolant for gti. Am I able to use the penrite universal or should I just use their g12 equivalent?
Thanks
A one-off top-up of water is fine.
If you're constantly topping it up, there's a problem.
A read of this old thread tells you a lot Penrite pink coolant is it really VW approved?
