Ibiglari: You do seem to have the most interesting problems - it's good to have you as a forum colleague!!
So, not sure if you are aware how/when component protection operates, but the master control module in the process is what VW calls J533 (data bus diagnostic interface) and what OBD11 calls the "Gateway" (at address hex19).
Every time that a terminal 15 switch-on sequence occurs (i.e. the ignition is turned-on), J533 takes a look at the identity of certain key control modules and it compares these identities with the data that it stored about these modules at the previous switch-on cycle. If the two identity lists don't line-up a component protection fault is initiated.
The suite of control modules that are checked by J533 form what VW calls a "constellation" and these modules include:
- J234 Airbag control unit
- J285 Control unit in dash panel insert (i.e. what OBD11 calls "Dashboard"
- J428 Adaptive cruise control unit
- J519 On-board power supply control unit (what OBD11 calls "Central Electrics"
- J533 Data bus diagnosis interface
- J685 Display unit for front information display and operating unit control unit
- J794 Control unit 1 for information electronics
- R Radio
If it is determined that a known constellation of devices is working in the same way as during the last driving cycle, then the control units are enabled for regular functions.
If this is not the case for a control unit, then the component protection is activated in this control unit, which has an impact on its function. For example, a classic symptom of CP for the infotainment unit (i.e. J794) is for the sound to be permanently muted (the unit otherwise works OK, but without sound). Another example is when the Dashboard module is locked by CP -all of the lights and the two clock dials permanement flash on/off and the center display keeps flashing the message "safe CP"!
When a component protection fault occurs in any of the constellation modules (usually) the ONLY way to remove the error is to visit your friendly VW dealer who hooks-up the car to VW's central database at head-office. (the system is called FAZIT). Supposedly, the database checks that the new control module hasn't been thieved and the entire palaver is meant to combat the black market for spare parts. Alternatively, some consider CP to be nothing more than yet another excuse to pay your local VW dealer for something that should be able to be managed outside the dealership. You can decide which is true!!
So with all this as background information, I'm intrigued why loss-of-volts caused CP errors ( without changing modules) and I'm even more amazed that you managed to delete a CP error though the sequence of steps that you describe (i.e. without the involvement of FAZIT) -The identity list for the constellation in J533 is kept in non-volatile memory - so loss of volts should not affect the database. And, even though no control modules in the "constellation" were actually changed, once the CP error occurs, it is meant to be permanent without a fix via FAZIT - extraordinary!!
