Originally Posted by
Diesel_vert
You have to consider the static radius, which takes into account the deflection under load, because a tyre is deformable and not perfectly round. The amount of deflection mostly varies depends on the aspect ratio.
And yet, you fit 205/50 R16 tyres and 16" wheels?
There's no such thing as a free lunch.
-Fitting bigger wheels with appropriate sized tyres usually means less compliance, more unsprung weight and more fuel consumption.
-Fitting bigger tyres to compensate for reduced compliance leads to additional increases in ride height, unsprung weight and fuel consumption.
-Fitting bigger wheels and tyres that weigh the same as the original setup, or less, costs more $$$.
-Fitting suspension components that either lowers the vehicle or improves compliance also costs $$$.
-Fitting suspension components that can do both (if possible) will cost you even more $$$.
-Inconvenience is the price you pay for aesthetics, though that too can be rectified with $$$.
Etc.
As far as I can see, the most effective solution is to eliminate the cause (remove the big & heavy tyres and wheels) rather than solve all the issues it's creating.
Alternatively, just put up with the ride height and keep the compliance, or lower the vehicle and live with the ride quality. You can always do both (probably?) but that would require $$$.
