Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: Cold Air Intake - Advice
    Feb 2010
    Quote Originally Posted by Fixxxer View Post
    Nice photos.
    They tucked the intake up to the grille and above that flap area to stop any chance of water or stones/other junk from getting into the intake.
    Not much space to do much, I imagine that even trying to fit a pod fliter would be difficult due to the space contrainsts? How much room is there?
    Also, that pipe into the turbo inlet is tiny! It looks like a small radiator hose!
    Fixxxer
    Yes it is very tight, I am not sure how fitting a pod would go...
    2020 VW Golf R
    Sep 2010
    Singapore
    Hi all, here is my intake:
    Feb 2010
    Quote Originally Posted by Echizen View Post
    Cool! Still looks like it has a few bends... Noticeable difference? How much did it cost? Where did you buy it from? Was it custom or actually made to fit into the 1.2 tsi?
    2020 VW Golf R
    Feb 2010
    Actually I found this thread:
    Intakes and Exhausts - APDrive - Page 5 - VAGSG Community
    Is that your car? Colour looks the same!
    2020 VW Golf R
    Sep 2010
    Singapore
    Quote Originally Posted by Allegiance View Post
    Yes that's my car. Better pick up noticeably from mid-high end. Cost me 400+SGD . Got it from apdrive. Mine was the first polo to be fitted with itg locally so you can say that it's custom fitted.
    Jan 2008
    Sunshine Coast
    I'm gonna ponder this today, but agree Scott is definately on the money. What's the chances of moving the battery back, or drawing air from the passenger foglight shroud area?
    Feb 2010
    Don't think you could move battery, it is well secured. I have the sports pack so I use both fog lights... Or did you mean somewhere else?
    2020 VW Golf R
    Adelaide hills, SA
    He probably thought, to relocate the battery to the boot.
    Gosford Central Coast NSW
    Fixxxer
    The turbo inlet is also tiny. If ther must be a bend before the compressor inlet, theres merit in keeping the pipe diameter smaller, as it keeps the air velocity through the bend high, which keeps flow into the compressor happy when its spooling (coming on throttle). This is a design feature vw have employed to improve "driveability"
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
    Jan 2009
    blankedy
    It might be worth measuring the pressure drop as was done on the last Polo...
    I can see what you are saying and that the flow looks restricted, but if you test it you may see that the intake is not overly restrictive and that cash could go elsewhere...
    From memory, it was the MAF that posed the biggest restriction in the last Polo GTI.
