Page 3 of 3 FirstFirst 123
Results 21 to 23 of 23
Thread: Coilover Install Melbourne
  1. #21
    Dec 2012
    Moe Victoria
    Not sure if you can enlighten me on this?
    The original VW nut holding the front strut piston rod is 21mm A/F. This is a self locking galvanised? flange nut.(no spring washer)
    The Koni supplied nut is zinc coated 22mm A/F and comes with a spring washer.
    Is there any reason why I could not use a new original VW nut. Makes tooling so much simpler.
    It seems some have used a 22mm deep socket, machined 2 flats on it. Then used a crow foot adaptor to tighten and torque.
    Koni recommends a tightening torque of 80Nm for the 14mm x 1,5 pitch thread.
    VW recomments 60Nm for their nut which has the same size thread.
    I am thinking using VW self locking nut and tighten to 70Nm (split the difference)
    Any thoughts?
    VEEEUU
  2. #22
    Jun 2008
    Emerald, Vic
    I filed 2 surfaces on a 22 and used a deep Allen key as u say. I have never torqued them up past 'yep, that ain't going anywhere', I periodically checked them but they didn't move. A dab of locktite and it's all good.
  3. #23
    Apr 2015
    Berwick
    Hi guys I know it's a little late but first thread I've seen quiet suitable to my need as well.
    Have my mk4 with coilovers and got quoted 600 for installation from a few places.
    Where can I get them done For these prices I'm reading. Also located in narre warren!
