Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Changing polo tsi Springs to gti springs
    Erskineville, NSW
    The dampers in polo are absolute rubbish. The barely control the spring oscilations.
    You are better off changing the dampers to Koni or Bilstein.
    As a DIY you need the spreader for the hub joint and the correct tool to undo the top nut of the strut.
    You need to be a bit imaginative if you don't want to undo the drive shaft bolts.
    The rears are a doddle and take about 15m per side. The fronts take about an hour per side.
    You can do the dampers & leave the existing springs in and it will transform the car. If you do just the springs on the existing dampers it will be even more over-sprung / under-damped.
    Dec 2015
    roxburgh park, vic
    I don't drive that far most days for work and I don't mind it a little firmer
    Erskineville, NSW
    I don't think you understand what under-damped is. It's not about firmness - it's about the body bouncing like a pogo stick
    Dec 2015
    roxburgh park, vic
    Hmm never thought of that. Thanks for the idea. I'll check prices but I have found a full set of gti springs and shocks for a very good price in which I will end up getting. Unless the price for the shocks are at the same price
