Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: CEL for a short time...
    Jan 2009
    Sydney Norther Beaches
    Great to hear a positive dealer experience
    Jul 2012
    Sinagra, Western Australia
    Quote Originally Posted by nomadx38 View Post
    A ping is a misfire - a misfire been a ignition that was not planed so it could be late / early or not fire at all.
    I have never heard a car which is running normally and pings (actually it sound more like popcorn popping instead of a high pitched ping)
    As Umai said, as misfire is a cylinder which is failing to fire/ignite. Although the term is abit misleading.
    I've always found pinging to sound like two tiny hammers to be tapping against each other.
    Has the car been serviced recently RUFNIT ? That usually occurs from either the filter being dropped, being tightened too much or someone forgetting the old seal in the housing.
    Jun 2013
    Brisbane, Queensland
    Yep the car was serviced last month...
    MR
    MY 13.5 Candy White Polo GTi, with Xenons....
    - Gloss Black roof, Weitec, Whiteline, APR and Harding Performance bits
    - Sound, Mosconi D2 100.4DSP, Mosconi D2 150.2, HAT L6SE Carbon
    List of things to add, custom built subwoofer enclosure by Drivesound
    Jul 2011
    Quote Originally Posted by Snail Style View Post
    Meh depends how you look at it
    I go by what the internet, workshop manual and VCDS tell me - Misfiring is a general term used to describe an incomplete combustion within a engine cylinder - the main cause of a engine misfire been a miss-timed combustion event.
    Anyway glad the problem was solved funny that it could be somthing as simple as oil pressure, just hope no other damaged has been caused as a result.
