As Umai said, as misfire is a cylinder which is failing to fire/ignite. Although the term is abit misleading.
I've always found pinging to sound like two tiny hammers to be tapping against each other.
Has the car been serviced recently RUFNIT ? That usually occurs from either the filter being dropped, being tightened too much or someone forgetting the old seal in the housing.![]()
