Page 1 of 5 123 ... LastLast
Results 1 to 10 of 41
Thread: catalytic converter light and EPC light (solid) - advice please
    Aug 2006
    Far North Qld
    catalytic converter light and EPC light (solid) - update
    last night cat converter light started flashing (intermittently), today it was intermittent and then solid...a bit later, EPC came on as well, and now both solid.
    manual says to drive to nearest dealer. In my case a 30km drive in the morning on the way to work, mostly down hill and flat.
    Car has been misfiring a little in last two days, especially on start up.
    Question: will it be ok to drive to dealership in morning, in the hope they can look at it without it having been booked in...?
    obviously i will be taking it very easy...but still...
    thanks in advance
    White 3-dr Polo GTI
    Tiguan 189TSI
    Sep 2012
    NSW
    Call VW roadside assist. They will get NRMA to come look at it, if it isn't in good shape drive, they will tow it for you to the nearest vw.
    May 2011
    What colour is it, orange?
    I had that with mine - it says Catalytic Converter in the manual but it's just a general warning light. I had this after 3 weeks in my car, the Brake Vacuum Pump had failed. I had a burning smell coming from the car so it was towed to the nearest dealer.
    Would definitely get VW assist to look at it before driving it anywhere......you don't want to drive it and then something else happens and you get the blame
    Polo GTI - 5 door - Candy White, Xenons, Comfort Package, Audio Upgrade, Bluetooth, Parking Sensors and Tint
    Yarraville, Victoria
    Had the same light come on and it turned out to be the Brake Vacuum sensor.
    Had it replaced by the dealer but the light came up after 100km.
    So back it went to the dealers. Apparently they needed to do a "software upgrade as per instructions by VW" which seemed to do the trick.
    Jul 2012
    Coogee, NSW
    Brake vacuum sensor, mate had this problem as well, get it towed is your safest option
    MY11 Polo Trendline, Candy white
    RCD510, R badge, AP X coilovers, 17" Ariettas in gloss black, Rear muffler delete, GTI pedal covers, gloss back emblems
    soon to come, Front lip & Fat bottom steering wheel
    Aug 2006
    Far North Qld
    thanks all, RACQ came to see me at home, said it was safe to drive to dealer...
    car has never run so lean...feels like only running on 3 cilinders...
    will find out later today what the damage is.
    cheers
    White 3-dr Polo GTI
    Tiguan 189TSI
    Aug 2006
    Far North Qld
    car's been at dealers since Tuesday morning, and they still have not given me an indication of what is going to happen, other than to say the car will be with them for quite a bit longer...
    What's a reasonable time by which I should be able to expect this advice?
    I thought 4 days is pretty reasonable..
    they've asked me for proof that I'm using 98Ron fuel, and that's about it
    your thoughts?
    White 3-dr Polo GTI
    Tiguan 189TSI
    Sep 2012
    NSW
    Sounds like a similar thing that happened to my car. They had the car for 2 weeks, although I had a long list of issues. Turns out they only replaced the sparkies to fix the issue. I was sceptical, but it has been running for 1500km now, and no dramas.
    I know for a fact the VW are testing the fuel quality when there are mechanical engine issues, I know of several twinchargers (dead) in Melbourne (unmodified) that have been refused warranty when 91 ron was discovered in the tank.
    That will be the request for fuel proof.
    Aug 2006
    Far North Qld
    got a call from dealer and VW Assist today...
    one of the pistons is burned, but they are still trying to determine the cause...
    meanwhile, will likely get a Europcar loan car today, will be a nice change after Nissan Micra for the last week...
    I'm thinking this will likely take a while to get sorted.
    cheers
    White 3-dr Polo GTI
    Tiguan 189TSI
