Page 3 of 3 FirstFirst 123
Results 21 to 27 of 27
Thread: Carbon build up......77tsi???
  1. #21
    Quote Originally Posted by bigfoot View Post
    just got a call from my VAG dealer and apparently the car has carbon deposits in the injectors ($220 to flush) and throttle body ($120)
    You'd have to ask yourself what mechanic would do that much work (which isn't part of the service) to find out there were all these deposits etc BEFORE asking the customer who may then refuse to go through with the cleaning job.
    It's therefore a con.
  2. #22
    Nov 2010
    Sounds like a money grab.
    yea i'm a bit suss. if it was $100 or so i probably would have just done it but $340??
    i assume you can't simply unplug the injectors on a polo like you can on some other cars?
    MY18 Golf 7.5R - Ecotune Stage 1
    Mazda RX2 - 13B Bridgeport GTX4202R
  3. #23
    Erskineville, NSW
    By a bottle of Nulon Total Fuel System Cleaner & use as per instructions. it's <$20 & will clean the injectors as good as what the dealership will do.
    I'll make an assumption that you already use a brand name 98ron fuel?
  4. #24
    And if there is infact a carbon buildup issue after only 5,400km - then VW can kindly rectify the issue under warranty.
  5. #25
    Nov 2010
    Shell V-Power
  6. #26
    Erskineville, NSW
    Shell V-Power
    Well, that stuff is full of detergent, so you should be clean as a hausfrau's floor.
  7. #27
    Jan 2009
    Agreed.
    As far as the injectors are concerned, they shouldn't be suffering from carbon buildup, considering the type of fuel used and the low mileage.
