Results 11 to 20 of 27
Thread: Carbon build up......77tsi???
    Jan 2009
    Even if the OP had his first 15,000km service there would be some deposit starting to build up. It starts with the hydrocarbons that are in the air from the cars exhausts when you drive in city traffic and you stop at the intersections. The second is from engine’s blow by gases and recirculated exhaust gasses (EGR) that are rich in unburnt fuel and oil vapours. At the first you get only oil film on the inside of the intake, which gets thicker longer you leave it there. Then the soot (from the same source of hydrocarbons), sticks to that oil film. As you continue driving with that deposits in there, after while it all get baked (carbonized) and onto the metal surface it lays on. The first areas where you will spot it would be the hottest one on the valves and the top of the pistons.
    Ideally you should remove these deposits at every service while they’re still not baked onto. I recommend doing it every 15,000 -20,000km
    I see.
    That said, although it's satisfying to have an engine with spotless internals, I'd also be fine as long as the carbon deposits doesn't significantly affect performance. If you're a competent home mechanic who's passionate about cars, then I can see why you'd physically clean it yourself, but maybe a bit much if you have to pay someone to do it for you.
    It's when they start building up on certain areas (but not limited to) the intake valves, EGR, etc. which can really affect performance that I start to get concerned. Hopefully for the OP, it's the former and not the latter.
    Potts Point, New South Wales
    Would it benefit the vehicle to have a really good run at least once a service period.....IE: over 4 hours highway driving.....Would that lessen the build up of carbon deposits?
    Adelaide hills, SA
    Quote Originally Posted by Acko1991 View Post
    Not really. If you would drive only long trips and had less cold start ups, then you would have less unburned hydrocarbons, less soot and cleaner engine the inside. But one long trip wouldn't make difference.
    Jan 2009
    If the engine has a fundamental design flaw, then no amount of driving will really prevent it. It may perhaps reduce the rate of buildup, but ultimately, you'll need to dismantle the engine and clean it.
    At the same time, not all engines are affected to the same degree. As the 1.2 TSI hasn't been around for that long, I don't know if it's particularly prone to fouling up its intake valves. Also, the OP mentioned buildup in relation to the intake manifold, not the intake valves themselves (though feel free to correct).
    For example, in this article (Direct Injection Fouls Some Early Adopters), some engines from other manufacturers have managed to avoid such buildup.
    Jun 2008
    Ringwood, Victoria
    Would you guys recommend Seafoam to sort out the carbon build up?
    Adelaide hills, SA
    I use BG equipment and really like the results.
    Does petrol and diesel, cleans EGR in the diesels and their chemicals continue to clean even after combustion. Expensive but worth every cent.
    Set up in my T5
    My new toy.
    It's all part of my service
    Jan 2008
    Sunshine Coast
    F$%king awesome!!!!
    Adelaide hills, SA
    Quote Originally Posted by Greg Roles View Post
    F$%king awesome!!!!
    Yes it is. It’s a perfect addition to my Interject injector cleaning machine. I got it just a week ago after researching the market for a while. The results are really good. I still have to make the adaptor for it to be able to use it properly on the VW TDI's due to the clip on the T/Body. The diesel system has electronic box with the injector that is pulsed - there are 2 settings. The atomization and consistency (coverage/sprad) of the chemical is vital, that's why you don't get the same results from the spray cans. My son's in law RS Octavia TSI is close to 30,000km and I will make sure that I have a lot of time for the service to take some pictures of the engine internals, just wish that Snap-on bore scope camera (it takes video too) was higher resolution, ah well, maybe it's the time to upgrade it as well.
    Nov 2010
    just got a call from my VAG dealer and apparently the car has carbon deposits in the injectors ($220 to flush) and throttle body ($120)
    does this sound right for a car that has just ticked over 5400km or can it wait until the annual service in october, by which time i'd be lucky to have done 6000km?
    MY18 Golf 7.5R - Ecotune Stage 1
    Mazda RX2 - 13B Bridgeport GTX4202R
    Erskineville, NSW
    Sounds like a money grab.
    I'd ask him how he ascertained that carbon was an issue. Ask in writing and ask that his reply be in the same format. The only way of inspecting these items would be by removing spark plugs & intake pipes & visually inspecting using a borescope.
    After receiving their reply, I would then contact VWAU & ask them to pay for the repair.
    Truly, find a new service centre. You are dealing with crooks.
