Results 1 to 8 of 8
Thread: Camber adjustment kit rearwheel polo
    As Gav said, moving the beam is the only real adjustment.
    You can shim behind the stub axel to correct and adjust, but with such small measurements it'll be a night mare and probably cause more issues then it corrects.
    I wouldn't stress, my rear beam is at least 3mm off centre from factory on my mk4 . Most are out, you just can't see it
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
    Dec 2014
    Canberra
    I suppose I'm left wondering why did they not allow for adjustments in the rear axle
