Results 1 to 5 of 5
Thread: Cadiz rims on polo ?
    Jun 2018
    ACT
    Hi, does anyone know if I can put Golf R (MK VII) Cadiz rims (19" 19x8 ET50 5x112) on my VW Polo MY2011 77tsi Comfortline? Are they going to fit?
    Thanks
    Apr 2017
    belgrave victoria
    Quote Originally Posted by Malina View Post
    Thanks
    i would doubt it i think the polo studs are 5x110 and the rims maybe (definitively) to big for the space inside will maybe rub on inside
    Also they are 2 big for legal fitment your rims are i think 15 inch? max size fitted on polo is 17 inch you cannot go more than 15mm difference in rolling diameter than the biggest wheels fitted which would make the largest you could fit 18 inch with a decrease in tyre diameter to keep similar diameter overall i.e 17/45/215 and 18/35/225 or similar
    Best to look at a set of gti polo wheels in 17 inch will look plenty big enough on a polo
    2017 Golf Alltrack 135tdi All options
    19 inch Brescia Wheels Golf R brakes front and rear
    Calipers painted Candy apple gold
    New rear sway bar and linkages
    Polo is 5 x 100 and the Golf is 5 x 112 so you'd need adapters to start with. This will add 20-25mm thickness: Set of 4 Hubcentric Adapters | 5x100 to 5x112 | 57.1mm Hub | 25mm fits VW Audi
    You'd need to run 25 profile tyres to keep the rolling diameter the same.
    The combination of adapters and wider wheel will have the outside rim poking 47.1mm more than your stock set-up: www.willtheyfit.com - The Wheel Fitment, Tyre Stretch, Rolling Radius and Speedometer Error Calculator
    I wouldn't recommend it.
    Agree with above. Look for a set of Polo GTI wheels. This will fit up fine and keep it legal.
    Jun 2018
    ACT
    Thanks for the explanation
    Much appreciated !
    Apr 2017
    belgrave victoria
    Canterbury wheels and tyres in melbourne have a set of aftermarket gti polo wheels and tyres for about $1200 plus shipping on their website
